Verdigis on circuit board
    • 3468
    Noted some greenish discoloration on my Microgyro pitch controller.
    What could have caused it?
    Unit was in cabinet but never been in the water. Unit works just fine when tested. Click image for larger version  Name:	20241002_161738.jpg Views:	0 Size:	48.0 KB ID:	182947
  • DrSchmidt
    • Apr 2014
    • 1331
    Copper oxide is green....corroded contact?
    • wlambing
      • Nov 2020
      • 384
      High humidity has allowed build-up of copper oxide (verdigris) on the wire at the solder joint. Careful application of isopropyl alcohol with a cotton swab will remove it.
