Foam For Submarine Trimming
    • 1821
    I need help with the type foam we use for trimming out our submarines.. I used to purchase it from Nautilus Drydocks, but Bob no longer handles it.
    I found this on Amazon. It sure looks like the foam we use. What do you think?
    I know you might say just go to your local Home Depot store and buy it. My problem is due to health issues, plus I should not be driving with my poor eye sight. (MD) Would someone please look at this foam I located on amazon, and tell me if it would work or not? It looks very close to the small sample I have left from my inventory.
    Thank you in advance for your input.
    "Firemen can stand the heat."
    • 3549
    looks like what I use: https://www.homedepot.com/p/Owens-Co...E&gclsrc=aw.ds
      • 1821
      Thank you Tom,
      The specifications seem to be right on. I am going to go a head and order it up.
      Thanks again for your response and expertise Tom!
      • Bob Gato
        • 831
        Closed cell and will not absorb water...I use that foam to also build the plugs for my fiberglass hulls...it cuts well with a radial arm saw, table saw, band saw or hotwire foam cutter. It is easily formed with a vertical bench belt sander can be painted with rustoleum non spray paint... Glues well with 3m spray adhesive and can be drilled nicely with a sharpened brass tube... It also is extremely strong when laminated with thin sheet grp and epoxy resin.-BG
          • 1821
          Bob,
          Thank you very much for that great information. The 212 A that I am building and the EasyDriver for the boat is going to lend itself to being a dynamic diver only, and looking at one of Bob M. build on that boat there was quite a bit of foam installed in the top sections of the boat.
          We will see when that time comes. Thanks again Bob, always appreciate your input.
          • wlambing
            • Nov 2020
            • 295
            Midwest Hobbies used to have a nice, white, closed-cell foam in sheets (pkg of 3), about 1' X 3' X 3/8". Very easy to cut, and great for those hulls with limited annular space. The late Dave Welch made excellent use of this foam in his Gato fleetboat endeavors. Might still be available through a website or hobby shop.
              • 1821
              Thanks wlambing,
              I found this very foam that Tom lead me to on Amazon 18" X 12" X 3"
              I just did not need a 4' X 8' sheet of it..
              Thanks to all of you that responded. As always the answers are on this forum...
