German Type 212A 3D Print Build
    Work with what you've got, Rob. Keep slugging tough guy! Ya got back-stops here if you need 'em. Just call out.
    Thanks David!
    I will get this 212 built and in the water, one way or another for sure!
    "Firemen can stand the heat."
    Well after attempt and attempt, I am going back to my original design.
Name:	GERMAN 212 A 47.jpg
    My poor eyesight just won't let me work like I used to. And without elaborating I am going to work on the original method.
Name:	GERMAN 212 A 54.jpg
Name:	GERMAN 212 A 55.jpg
    This is the same design and method that Bob Martin (Nautilus Drydocks) uses on his new 212 A kits.
    Nautilus Drydocks 1:72 German Type 212 Instructions CH2 (youtube.com)
    The video above shows the installation process that I will be using.
    I am hooked and ready to go!!
Name:	GERMAN 212 A 53.jpg
    David M's influence strikes again! " It's hard to know which road to take without a map" I can now see that a SCALE drawing of the interior stern section will allow me to design a yoke
    (to scale) that will make fabricating and installing it much easier.
    I realize a lot of you will laugh somewhat at me putting up my drafting table, and that is fine, but I now understand how prior design and planning can make the overall fabrication go much better in our submarine building... And to that end, we build on!
    I was just amazed at the information dump in your post. David you hit everything from search for lost sub to electronic schematics. Amazing work. I will be downloading these images.
    Tom,
    I have got to agree 100% with what you have stated. And I do appreciate all the input I am receiving. David is such a master at what he dose. I so respect his methods of achieving.his end results. His engineering drawings, methods of fabrication, set up, final detail finish work, and then the final masterpiece. What more can I say! Except to thank him for all the advice and help he has given me along the way!!
    I do not want to slight many others who have been very helpful to me as well, and that includes you Tom!!
    Rob,
    Crazy idea while sleeping or on the ****ter; discussion with peers; paper-napkin doodles; cardboard study model; detailed shop drawing(s); prototype construction and evaluation; Identify ****-ups; repeat.
    Originally posted by Ken_NJ
    Some of your artwork David looks good enough to frame and hang on the model submarine builder nerd's office or shop! Love the artwork!
    Here's one I have in my office that a friend did.
    Click image for larger version  Name:	IMG_3646.jpg Views:	0 Size:	44.7 KB ID:	178970
    That illustrator provides so much direct and indirect information; all done in two projections of the same item: the plan orthographic permits direct measurements to be lofted to the work (pure layout gold). The bottom perspective projection conveys rough dimensions not suitable for lofting but highlights the three-axis relationship between all items presented. Add a profile orthographic projection to this work and you have everything needed to array the devices presented. Yeah -- I would frame and hang that illustration as well, Ken. Excellent work.
    Some of my refined illustrative work has appeared in books, one book jacket, instruction pamphlets, industrial house organs, catalogs, box-art, and numerous magazine articles.
    One book, without permission, mistakenly published one of my three-views as source material -- when in fact it was nothing more authoritative than 'fan art'.
  • Ken_NJ
    Thank you very much for the great photos and the illustrations. I will be using your brass yoke designs and especially your layout work before your fabrication. I am really starting to appreciate a scale drawing prior to fabrication.
    Thank you for your time and expertise ounce again David.
    My pleasure, Rob. The layout process, so unappreciated by so many. Hard to pick the correct road without a road-map.
    Bruce,
    Here are the dimensions of my hull, and at this point about where the cylinder will be located as well.
Name:	GERMAN 212 A 52.jpg
    The overall length is 31"
    Measuring from the front of end cap to the bow opening is 6"
    Hope this helps you.
    Thanks Rob
    This is what I think will be my solution to solve the stern section interior!
Name:	GERMAN 212 A 49.jpg
ID:	178951 Click image for larger version
Name:	GERMAN 212 A 50.jpg
    I used Simplify 3D slicer to cut the stern section into two separate pieces. This will give me much better access to the control linkage installation. As stated above, I am going with 1/16" stainless steel rod in place of the brass.
Name:	GERMAN 212 A 51.jpg
    Bruce,
