Anyone Have A Fittings Kit For A Bronco XXIII?
    2028........?
    I'm an idiot!
    ... 2023
      • Jan 2020
      • 1036
      anything but!
      • tifosi12
        • Jul 2020
        • 418
        Like so........................
ID:	174009 Click image for larger version
ID:	174010 Click image for larger version
ID:	174011 Click image for larger version
ID:	174012 Click image for larger version
        I know. We had this discussion back then and you showed these pictures and I tried. Built a jig for the dremel and tried the cut. Still couldn't pull it off: The plastic hull would bend ever so slightly and the result would be a non straight cut. I tried several times, that's how I ruined a bunch of Bronco kit hulls, but none would cut nicely. Even when the cut was ok-ish, I would end up with too much material lost between the halves to have a nice closure. In addition the two halves are too thin to sit nicely on top of each other.
        Your photos make it look so easy, but I know different. It looks so easy because you are a master at what you are doing. Not because it is actually easy.
          • Jan 2020
          • 1036
          anything but!
          If you still have those kits would you like to sell them? I could make fittings from the rudder and planes etc. to share.
            • Jan 2020
            • 1036
            and so............
ID:	174015 Click image for larger version
ID:	174016 Click image for larger version
ID:	174017 Click image for larger version
            Oh My Lord, care to sell that Type XXIII?
              Originally posted by tifosi12
              ... I would end up with too much material lost between the halves to have a nice closure. In addition the two halves are too thin to sit nicely on top of each other...
              How to make up material lost to kerf.
ID:	174047 Click image for larger version
ID:	174048 Click image for larger version
ID:	174049 Click image for larger version
ID:	174050 Click image for larger version
                I created the prop shaft base in 3D resin. I will be working on the rest like WTC bulkheads, but not the dive planes. I do not think that is necessary (although all of it is not necessary really) because it is simple enough to convert the subs kit planes. Don't you think?.
                  • Jan 2020
                  • 1036
                  Oh, I thought it was completed!
                    The Type XXII is my next 3D Print Project. I have contacted Danny Engelhardt​ with Maximus. He has the fittings. I will update his response when/if I hear from him as to wether he will sell the files or fittings to us. If I design them myself I will share them. I wish Randy Sanders would design Type XXIII STL's thru Bob.
                    I’m pretty sure Maximus uses the Bronco kit, and only manufactures the WTC, not XXIII.
                      • Jan 2020
                      • 1036
                      Correct, but he fabricates the fittings to use with the Bronco kit
                        Great. Let me know what you hear.
                          • Jan 2020
                          • 1036
                          I will update you
                          • tifosi12
                            • Jul 2020
                            • 418
                            As I said, you're a master at what you do. I'm a mere mortal.
                            • tifosi12
                              • Jul 2020
                              • 418
                              Sorry, all gone a long time ago.
                              • tifosi12
                                • Jul 2020
                                • 418
                                #30
                                While I said that I would never build a plastic conversion again, I have to admit that in my closet I still have the Lindberg IJN I-53 model kit and I do want to build that one day. I'm hoping in that case that a cut of the hull won't be necessary and that I can use the "natural" deck line as a removable top akin it is done with the Revell Type VII boat. Not to hijack the discussion here. Maybe somebody else will do the same thing and share some build progress on here?
