Color of U-3008
  • cgbillb
    • May 2018
    • 182
    Color of U-3008
    Does anyone know what US Navy color the US U-3008 would be?
    This photo is when she was in Portsmouth N.H. around 1946.
    I like to paint my model as close to the right color as possible.
    Bill
    Athens Ga.
    Best I could find.
    • cgbillb
      • May 2018
      • 182
      Yes, I have all the photos of the USS U-2513 and the USS U-3008 but not colors, however I did just find this, so Light grey on hull and Black on decks.
      Paint Color for USS Type XXI
      As a result of these trials the US Navy concluded that a simple overall light gray hull and black decks provided as good visual protection as any other method. Consequently, U S submarines were painted overall light gray with black paint on the decks and on the outer surface of the ballast tanks.
      this is what I found from the Nation Archives on painting our USS U-2513 and USS U-3008.
      So Light Grey and Black deck it is.
      Thanks for the help.
      Bill
        • 1393
        • cgbillb
          • May 2018
          • 182
          Wow I did not have that photo, thanks. Do you know where and when it was taken?? After 1946, had sail change.
          Thanks again
          Bill
          Athens Ga.
            • 1393
            No idea....found it on pinterest
            • cgbillb
              • May 2018
              • 182
              ok cool I will research it tomorrow, I think it is PNY .
              Bill
              • wlambing
                • Nov 2020
                • 398
                Bill, you are correct. Test and evaluation of U-3008 was done at Portsmouth Naval Shipyard.
                Another Bill
                • Scott T
                  • May 2009
                  • 414
                  Searched Edward Tambunan
                  • cgbillb
                    • May 2018
                    • 182
                    Another Bill
                    Yes I have must of the records when she was there, But I have not found if her sail was replace there or in Norfolk.
                    Bill
                    Athens, Ga.
                    • cgbillb
                      • May 2018
                      • 182
                      Thank you Scott
                      Bill
                        Bill
                        I did some sleutering regarding camoflage as I'm building an 1/72 Iowa BB turret.
                        Came across these sites...apperently for submarines (SS) measure (design) 3 & 9 were applied during WWII, where Measure 3=Light Gray System (as you mentioned) and Measure 9 =
                        Black System for Submarines.
                        Mabe it will be helpfull for others also.
                        This page provides information U.S. Navy Camouflage Measures 31, 32 and 33, with links to presentations on these measures' individual designs.
                        camouflage, Naval warfare, ship camouflage, naval camouflage, dazzle schemes, razle dazzle, battleship, aircraft carrier, cruiser, destroyer, minelayer, amphibious, paint
                        Grtz, Bart
                        • cgbillb
                          • May 2018
                          • 182
                          Grtz, Bart
                          Thank you very much, I will check them out in the morning. Good luck on your build.
                          I am trying to clean up my library so many books so little space to put them.
                          Later
                          Thanks again
                          Bill
                          Athens Ga.
