Reduction Gear/Belts (Timing Belts)
  • SubSteve
    Here are a couple of belt drive setups from my USS Marlin. I fried the 380 brushed motor and replaced it with a small brushless.
  • RanSan
    Great info from everyone,thank you. Fusion does have an add on for generating gears which works pretty good. For the power train I assumed some kind of metal gear would last longer. What are people’s experiences with printed and what filament have you used? Any comments on wear using resin gears?
    thanks again.
  • Ken_NJ
    Probably not much help in a submarine. My pulley setup is on surface boats. I have more room to do this.
    The mounts on this boat were made by a machinist friend, actually his son, a long time ago. Never had a use for them until now. The center distance is adjustable by moving the motor. Ratio is 2:1.
    These were made by my machinist friend who recently passed away. Different that they clamp onto the stuffing tube. This boat has many "miles" on it. Never took them out for maintenance. Think these are 1.5:1 ratio.
    Demystifying Gearing and Gearboxes
    What am I thinking?!?! Dave actually use to cast his 3:1 reduction gears...CHIME IN Luddite!!
    The motor pinion and output spur -- both products secured from Stock-Drive
    Pinion-Wire-and-Spur-Gear-Stock-Inch.pdf (sdp-si.com)​
    Gears: precision, commercial, inch, and metric sizes | SDP/SI (sdp-si.com)
    I cast the motor-bulkhead gear housing to suit a particular flavor of WTC.
    Tutorial on creating GT2 pulleys with parameters.
    You can generate a DXF file with this, then port it into any cad package and extrude a pulley.
    Generate box for laser cutter or download drawing
  • QuarterMaster
    Originally posted by RanSan
    Thanks for posting this Ed. I want to go old school bushed motor on my Seawolf because it has room for the lead acid battery and the idea of the flaming Lipo frankly scares me a little.
    If anyone has some pictures of their setup and doesn't mind posting I would be interesting in seeing how they mount the motor and gears. What kind of mounting block they use and any information they can share with us newbies that are interested in the way "things us to be" I would enjoy seeing it.
    Randy
  • QuarterMaster
    Randy
    Dude,
    Is there a Gear plug-in for 360? There was one for FreeCAD. I was able to resin print my own Rack and Pinion for a Snorkel Mast operation assy.
  • RanSan
    Randy
    Difficult to top GT2 belts and pulleys, more than adequate for almost any size of model sub. Available cheaply on ebay. Does help if you can machine your own bushes, then you can purchase pulleys with the less expensive generic bore sizes. If you have a 3d printer you can also print pulleys, but they never run as smooth and clean as the machined aluminium ones, a resin printer would probably fair better in this regard.
  • Ken_NJ
    I just bought a 2:1 timing belt reduction set for a model I'm building. The SDP center distance designer works great. Enter your desired gear ratio and the center distance. Based on your input, it gives you choices for pulleys and belts. Most likely you'll use DF or double flange pulleys, then choose your bore (shaft size) and belt width. Most likely you'll use 0.080 MXL pitch.
    Great information Ed!
    Thank you for posting it up!
    "Firemen can stand the heat."
  • QuarterMaster
    FWIW,
    McMaster Carr AND Amazon are sources too. Check Price comparison for what you want.
    Here's even ANOTHER source w/Calculator!
    BELT LENGTH CALCULATOR
  • QuarterMaster
    started a topic Reduction Gear/Belts (Timing Belts)
    As promised...
    Designatronics, INC
    Address: 250 Duffy Ave Suite 2, Hicksville, NY 11801
    Phone: (516) 328-3300
    They have CAD models Ralph!!
