basic question (hopefully not too dumb =P )
  • GwenB
    • Oct 2022
    • 87
    I want to add 4 led navigation lights on my type VII. Obviously the point where the wire exits the WTC needs to be sealed around the wire, but does the wire for a low-power circuit like that need to be completely waterproofed? I would think it would... Obviously this applies to the led's as well. And if it does need to be waterproof what is the commonly accepted method for handling a circuit like this? I am thinking probably silicone sealant myself, but I would like to hear from someone who knows a little more than I do on the subject.
    Thanks guys,
    Gwen
    • 13528
    OK to put all the wiring, resisters, connectors, plugs, and bulbs in the wet. Not OK to run the wire directly into the WTC -- water will find its way between conductor and insulation. Use threaded conductive studs to isolate water from the WTC's interior.
    • GwenB
      • Oct 2022
      • 87
      Thanks, that is most helpful.
      Gwen
      • GwenB
        • Oct 2022
        • 87
        Thanks to your assistance here is what I did with my WTC:
        Click image for larger version  Name:	20221106_184413.jpg Views:	0 Size:	59.2 KB ID:	166550
        Click image for larger version  Name:	20221106_184420.jpg Views:	0 Size:	57.1 KB ID:	166551
        I tapped the holes for the studs through the bulkhead and screwed them through, then added washers and nuts.
        Thanks again!
        Gwen
          • 13528
          Perfect........................
            • 927
            Is that stainless steel? Better use brass for proper conductivity. Do not use galvanized steel, it will rust.
            • GwenB
              • Oct 2022
              • 87
              You're right. I will replace all those parts with brass after the next trip to the hardware store. =)
              • cheapsub
                • 192
                What about using a coin cell.
                if the battery is inside the wtc.
                  • 1959
                  The thing about LED lights is that they're a perfect indicator of sub power status. If they're on, you have it on. If they're off, the sub is off. People who rig them to switches really don't need to go to the trouble, at least in my opinion. No harm in having the lights on during the day, and if the sub is lost, the lights draw so little power that they'll probably still be on for hours after the sub is stranded on the bottom. Might make finding it at night an option...
