Russian Arcturus Concept Submarine Build
    Thrust vectoring nozzles instead of x-tail control surfaces.
    Originally posted by RCSubGuy
    The propulsion is going to be tricky. Very tricky. The linkages for the x-tail pass right through that area.
  • Bob Gato
    https://www.thedrive.com/the-war-zon...s-guard-drones I wonder if the concept changed from the X tail or to the X design
    I'm nearly through printing out the parts myself. There are going to be some fitment issues, but some work with a hobby knife will address them.
    The propulsion is going to be tricky. Very tricky. The linkages for the x-tail pass right through that area. Going to put some thought to it over the next few days and I'll post up what I come up with. Might help with your project, Rob!
    The stern section is complete!
    Based on the stern section files and by the looks of the my first print, this is going to be one "COOL" build!:-))
    Today I started on the stern section of the Arcturus.
    I did go with support structure even though it may have been a good build without. This build will take approximately 13 hours to complete!
    "Firemen can stand the heat'
    started a topic Russian Arcturus Concept Submarine Build
    New build!
Name:	Arcturus Submarine.jpg
ID:	166135Click image for larger version
Name:	ARCTURUS SUBMARINE 1.jpg
    This boat will be built using Nautilus Drydocks STL files. The material will be Dremel PLA and built on the Dremel 3D40 Digilab printer!
