I'm trying to set up differential thrust for propulsion and steering. I know any 6 channel 2.4 GHz transmitter allows you to mix the throttle and rudder channels. But my question is whether that also works with an "old" radio like e.g. the Futaba FP-T8UAFs? It allows aileron mix etc but would that work for throttle/rudder mix?
And yes I realize the Futaba FP-T8UAFs is a 72 MHz radio and thus a no-no for subs. It's just as an example.
Why am I not going with a 2.4 GHz radio instead? The antenna cable extension procedure scares the crap out of me. With my soldering "skills" that circuit would be dead within 2 microseconds.
