Differential thrust with a 75 MHz radio?
  • tifosi12
    • Jul 2020
    • 418
    I'm trying to set up differential thrust for propulsion and steering. I know any 6 channel 2.4 GHz transmitter allows you to mix the throttle and rudder channels. But my question is whether that also works with an "old" radio like e.g. the Futaba FP-T8UAFs? It allows aileron mix etc but would that work for throttle/rudder mix?
    And yes I realize the Futaba FP-T8UAFs is a 72 MHz radio and thus a no-no for subs. It's just as an example.
    Why am I not going with a 2.4 GHz radio instead? The antenna cable extension procedure scares the crap out of me. With my soldering "skills" that circuit would be dead within 2 microseconds.
  • tifosi12
    • Jul 2020
    • 418
    PS: Every time I google differential thrust with a RC transmitter I only get examples of 2.4 GHz radios. Hence my skepticism. I don't see why an advanced 75 MHz radio couldn't do it as well. If all fails, I'm actually thinking about programming an Arduino to put it in between the receiver and the ESCs. While not trivial, still better than soldering an antenna.... :(
    • Sinksalot
      • Mar 2020
      • 362
      Bob sells the Throttle Jockey that does what you want it to do.
      • cheapsub
        • 193
        Frankenstein transmitter (th9x) is under er9x, with a 12 channel RX , you could do all the mix you want.
        Or get a old radio mod the left side stick to 2 speed control stick. Just like the old ace sub commander.
        there's a YouTube about a 3d printing mod.
        • tifosi12
          • Jul 2020
          • 418
          Thanks much, I'll give that a try.
          • tifosi12
            • Jul 2020
            • 418
            Not following you on the Frankenstein transmitter. What's that referring to?
            • SubSteve
              • Apr 2022
              • 128
              Are you trying to control your port and starboard motors independently from the transmitter sticks or just mix rudder and throttles on the model to decrease turning radius? By the way, you will need two separate speed controls in the model for either choice.
                • 13667
                Grab an old AM Nautical Commander, gut it, and put the boards from an FM, 75mHz transmitter in there. Wa-la, two throttle sticks.
                Not worth the effort in my opinion.
                Learn how to solder, Damnit! You can't solder, you got no business in this game of ours.
                • cheapsub
                  • 193
                  For some reason ACE transmitter is about $300 each.
                  Cutting up a old transmitter. Click image for larger version
                  • cheapsub
                    • 193
                    This is the deep end of soldering.
                    Same but is out of control.
                      • 3493
                      How about a dual motor ESC?Click image for larger version
                      • tifosi12
                        • Jul 2020
                        • 418
                        I'm aware that I need two ESC. My goal is to eliminate the rudder altogether and steer solely through thrust differentials.
                        • tifosi12
                          • Jul 2020
                          • 418
                          I don't think that would work as that would make both motors go at the same speed.
                          • tifosi12
                            • Jul 2020
                            • 418
                            The goal is not to end up with two throttle sticks as that would be too difficult to run the boat (I only got two hands).
                            Actually I have soldered a lot in my life and that's precisely why I don't want to solder an antenna extension onto the tiny circuit board of the Rx: I know that either I'd produce a short circuit or overheat those electronics.
                              • 13667
                              If a club-footed, fat-handed, cross-eye'd creature such as I can solder without bridging closely spaced PCB pads, then so can you!! Use a 15-Watt iron with a pointed tip and you're golden.
                              David​
