Hms holland 1 build
    Thank you Bob! I have the pump that I am going to use! I did send you an email with the specifications...
    I didn't get your email, Rob... Can you re-send and let me know which email you sent to?
  • Sam Victory
    Redboat219,
    Sometimes I do admire your imagination and creativity,but sorry I'm a big submarine enthusiast and I've made it very clear, breaking down the pros and cons of peristaltic pumps, so if you'd still like to use a peristaltic pump in your little submarine, go for it, if you feel it's reliable. It's true that there is no such thing as standardization in making submarines, everyone is entitled to use what they want, it's just that I prefer to accept and learn from those who have come before me and then get what I want from them and innovate. Those masters summed up their experience through years of practice is well worth for those of us who come after them to learn, if you think I have a point, please think twice.
    If you still want to discuss about peristaltic pumps, please make a new thread and I will be happy to participate in the discussion, at the moment we are disrupting other people's threads.
    V
    Originally posted by Sam Victory
    Redboat,
    Making things simple rather than complex is appropriate for most people on this forum. You replace other good stuff (gear pumps, diaphragm pumps...) with a peristaltic pump that is inherently unsuitable for submarines. , why is this? Do you call this challenging yourself or do you like to keep repairing things?
    V
    Sorry Rob, i apologize from hijacking your thread.
    Sam,
    why don't you ask these guys, they chose to use peristaltic pumps with their boats.
    Trying something new! This is a 1:144 Kilo build. The Cylinder arrived from overseas today! Since my pool is 40’x20’ I have been looking for a smaller scale sub. My 1:96 scale Blueback does well, but not as nimble as this should be. Updates to follow!
    Rob,
    Let me know if you're interested in that pump and I can take some measurements to see if it will fit in your WTC.
    I just looked at a YouTube that Romel just put up!
    It shows how the Blueback WTC has the water pump for his ballast system installed on the very front of the WTC. His entire WTC concept is very similar to what I am trying to do with the HMS Holland build.
    Very nice Blueback build, and it performed very well in the water. It was a great presentation and I really like how he took his time to show and explain his WTC and ballast system that he fabricated.
    This is the type of stuff that makes this hobby so enjoyable and positive, great building and most of all the GREAT people!
    At the time I posted the video Nate wasn't yet a member of this group. It was too good not to share here.
  • Sam Victory
    -That's why it's important you do pre and post mission checks.
    -You'll probably lose your sub to something else before the tube breaks.
    -Life is too short. Be a warrior not a worrier.
    Redboat,
    Making things simple rather than complex is appropriate for most people on this forum. You replace other good stuff (gear pumps, diaphragm pumps...) with a peristaltic pump that is inherently unsuitable for submarines. , why is this? Do you call this challenging yourself or do you like to keep repairing things? Peristaltic pumps are commonly used in the medical field, such as liquid transfer, titration, quantitative testing, etc., so it runs very slowly.
    V
  • neitosub
    Thanks Rob! Yes, the ballast tank is 3D printed, I sprayed a few layers of automotive-grade filler primer on the inside and outside in order to seal the PLA against water and moisture. The ballast tank is actually too big and made the boat too negatively buoyant, so I had to squeeze in a lot of foam on the upper hull in order to get her sitting correctly at periscope depth.
    Nate
  • neitosub
    Thanks Rob! That’s actually my boat! I still have to take her out for her run this season, but that’s coming up soon!
    Nate
    To be honest, I don't really like using a peristaltic pump, even though it transports liquids in both directions. The reason is also very simple, in addition to it is very slow to transport liquid, there is a fatal disadvantage is its service life is particularly short, should be the shortest life of the pump. Peristaltic pump is dependent on the roller squeeze the tube to transport liquid, the longer the use of the effect will be worse because the tube will lose elasticity after too many times of squeeze, thus reducing the amount of liquid per unit of time. The most annoying thing is that you don't know when the hose will eventually rupture due to squeezing. Manufacturers have long done extensive experiments, the average life of an ordinary peristaltic pump is only four or five hours, in the case of non-stop operation. If one day, when you are operating the submarine process, peristaltic pump hose rupture, however, you have no idea, in the diving or surfacing process, peristaltic pump will let a constant stream of water come into the WTC dry space. The result is that a small amount of water accumulates and the eventual consequences are severe.
    V
  • neitosub
    Hi Rob,
    If inner space is the limiting factor, you can get away with having the pump on the exterior of the WTC, running in the wet. I have this setup in my Blueback and although it’s not ideal (the motor can get some slight corrosion on the brushes long term), it gets the job done since I don’t run that boat for long periods of time in the water anyways. As long as you dry the pump after every run, it should last you a while.
    Nate
  • Sam Victory
    V
    Diaphragm pumps will pump air or water quite happily, although my own experiments with them suggests that the pumps bog down very heavily when pumping water. Quite understandable when you consider the difference in density. The diaphragm pumps I've seen specified for water tend to have larger hose fittings. I wonder too if they have a lower revving and/or torquier motors. e.g. https://tinyurl.com/y2f6x5k3
    Course you can always use the pump you have, add another and use one to draw air out of the tank and the other to pump the water back out again.
    I have also seen these, although I haven't used them or known anyone else use them to date, but the spec looks good. Not sure if the parts are okay with water, e.g. use of carbon steel shafts etc.
    So if you try one, you may get arrows in your backside.
    Brushed
    https://tinyurl.com/2kkjm8yy
    Brushless- looks much more expensive, and probably not worth it IMO.
    https://tinyurl.com/5efes2up
    These are the pumps used in R&R modules. They used to have brass gears when they were made in France, but with production moved to China the gears are now plastic (meh!). They still work okay in aspirated tanks where they don't need to push against much pressure. Kavan pumps have brass gears, but they're much bigger and more expensive, although well worth it if you have the space.
    https://tinyurl.com/4zbhsu6b
    Alternatives, fit two unidirectional pumps one to pump in, one to pump out. Use a peristaltic pump- you can find printable versions on thingiverse. They tend to be slow at pumping compared to geared pumps, but a Holland has a low freeboard.
  • neitosub
    I have these in two of my boats, they work great and are fairly compact. One suggestion I have is to seal around the plastic casing with a bead of RTV silicone. I noticed that these pumps do cause condensation in the WTC after a run, most likely from small amounts of moisture leaking from the pump.
    Nate
