Airbrushing, new to me, looking for help advice
    Originally posted by Ken_NJ
    I tried something David does to props. I put toothpaste on a brush and flicked it on the test article then the model. Before I did that I sprayed the hull with a darker shade. Then with the toothpaste on a sprayed a lighter shade. Worked ok on the test article, not so good results on the model. The 'tan' color I was using always seemed to result in gray on the model. So I added some green to the the 'tan'. Pictures below are the result. Carol says this color looks more realistic to what I'm looking for. BUT, I think it might need an over spray of black? DAVID, need your option please.
    How it appears now, the large splotches are not as pronounced as they are. Good IMO. But now the base coat of black and red are not that noticeable and longer. I was hoping for a lighter BWL coating. There are plenty of pics of boats in dry dock that are covered in scum so I guess this is not that bad. I'm being to critical of the result. Well how it is is a boat that has been at sea for a long time.
    David, please advise.
    Click image for larger version Name:	4508C2BA-A97E-4D62-9D59-CF3631D1D285.jpeg Views:	0 Size:	66.9 KB ID:	160789
    Click image for larger version Name:	98BC1BD9-C777-4C0A-BBFD-6CCA35390C6B.jpeg Views:	0 Size:	79.1 KB ID:	160790
    My advice. Sure.
    STOP
    You anal-retentive, never-happy-with-what-you-did, perfectionist, insufferable rivet-counting, pain-in-the-ass! Just STOP! It's good enough... I said so!
    Yank the masking, apply the markings, lay down the bird-****, and give that thing a thick coat of well flattened clear and move on to the next model.
    You're fixating on this thing; you're no longer objective, you've lost perspective; you can't see the tree for the forest.
    You got to get this awful looking model submarine of yours trimmed and checked out for Groton. Time's a wast'n!
    Don't make me come over there!!!!!.....
  • Ken_NJ
  • Ken_NJ
  • wlambing
    Ken,
    Got your point! I mentioned the green fade as that is how the creatures grow in relation to the available sunlight. Nothin' pretty about it on the big ones!! Smelly, too, when in drydock!!!
  • Ken_NJ
    Thank you Steve and Bill. Based on comparing my test article to the model I could use more layers and lighter layers. I am just not happy about the large splotches but I understand patterns on growth can be random and different on each boat. I have an idea I am going to try on my test article first and see how that works out. Bill, I might not do the faded zone you mentioned, I would like to, but I will be adding everything else you mention. The goal is to not have the boat look pristine, something I have not done in the past.
  • wlambing
    Ya know, Ken, the real ones don't all have the same crap attaching to their hulls! IMHO, if you were to stop beating yourself up and do the light tans (dead stuff) and the greens (live critters) for the scum line, with a light fading zone of green from waterline to main axis, you would have a stunner!!! Oh, and don't forget goose poop on the turtle back and gull crap on the rudder and sail surfaces!!! Overall, what you have is great!!! Remember, Perfect is the enemy of Good Enough!!!!!!!!!!! Been there and have lived with all manner of weathered 1:1 scale submarine hulls.
    Take care,
    Bill
    Try more layers. That was the advise I got when I reached the same place you are at and it worked.
  • Ken_NJ
    Will try that misting next week.
    NOT HAPPY how the BWL came out. Does not appear like the test article I was working on. Seems when the toothpaste was removed, it removed the previous coat or coats of weathering leaving big splotches. The base coat was sanded and wiped clean. Either the previous coats were not fully dry or maybe the acidity of the toothpaste was the cause. And the tan came out not to my liking. Don't know at this point. Like I said, not happy how it came out. Followed exactly how I did it on the test article.
    Click image for larger version  Name:	IMG_4169.jpeg Views:	0 Size:	61.8 KB ID:	160625
    Click image for larger version  Name:	IMG_4170.jpeg Views:	0 Size:	51.9 KB ID:	160624
    Click image for larger version  Name:	IMG_4171.jpeg Views:	0 Size:	59.1 KB ID:	160628
    Click image for larger version  Name:	IMG_4172.jpeg Views:	0 Size:	58.0 KB ID:	160627
    Click image for larger version  Name:	IMG_4173.jpeg Views:	0 Size:	61.3 KB ID:	160626
    Click image for larger version  Name:	IMG_4175.jpeg Views:	0 Size:	56.6 KB ID:	160623
    Is this visible in pictures? If so you have any? I didn't see this mentioned in your weathering thread, and other posts, which is the basis for what I have been doing.
    If I have this right..... this is very thin streaks of a mist of dark-dark gray over some of the more pronounced white streaks. Then over that, a misty over spray of the same dark dark gray but in a wider fuzzier pattern. Is that it? More practice on the test article.
    Nope, no shots of the dark-dark 'correcting' streaking and over-spray. You got the process right. Not hard to do and will further enhance the appearance of 'reality'.
  • Ken_NJ
    Misting more darkness over the white streaking would subdue it more? I guess the key word is mist, an even lighter mist than spraying the base coat over the works?
    Mist yes, but up close and directed at the too-strong white streaking -- vertical passes only. Like you are a porn touch-up guy gently making pubic-hair go away on prints suitable for a 60's 'men's' magazine lay-out.
  • Ken_NJ
    Now, to make it pop: streak a bit of dark-dark gray over the subdued white streaking, then mist more dark-dark gray over all that.
  • Ken_NJ
    Here is the port side of the sail. I will be finishing the sail once the hull is done.
    Click image for larger version  Name:	E4517120-9D39-402D-B15B-AA63B1506C56.jpeg Views:	0 Size:	70.7 KB ID:	160488
    Now on to the below the waterline.
  • Ken_NJ
    These are with the base coat and clear coat. I feel like I could have not made the base coat so heavy so the streaking would show thru more. First pic is spraying the base coat over the streaking. The rest of the pics are the final product. I think it will have to grow on me.
    Once everything dried for two days, I wiped the surface with wet paper towels. The clear coat left the surface slightly fuzzy. I then lightly sanded vertically with 600 grit wet sandpaper.
    Click image for larger version  Name:	AF5196AD-AA8F-40F1-B87A-A236584AE0AE.jpeg Views:	0 Size:	66.9 KB ID:	160481
    Click image for larger version  Name:	BD045D4F-CAB1-4CA9-9015-03EF30328AAA.jpeg Views:	0 Size:	63.2 KB ID:	160482
    Click image for larger version  Name:	4A2CBDD6-1491-4583-8EC9-684C922FF332.jpeg Views:	0 Size:	64.4 KB ID:	160483
    Click image for larger version  Name:	AC9C6DBF-BA8D-40E7-AE33-BA8554F4E5DB.jpeg Views:	0 Size:	68.3 KB ID:	160484
    Click image for larger version  Name:	963F8D2C-3E27-4E93-878D-42DB3C5239B9.jpeg Views:	0 Size:	64.9 KB ID:	160485
    Click image for larger version  Name:	9AF4A590-A958-4F32-AA36-00A0E8D07FEF.jpeg Views:	0 Size:	66.5 KB ID:	160486
