Thanks Nate, I do appreciate the input!
I have never used brushless motors on any of my subs before, but I thought this might be a good way to go with this particular build.
Russian Alfa Class
It would work, Bob is using them on his new line of WTCs. Just make sure to use a bidirectional brushless ESC to get forward and reverse.
NateLeave a comment:
I have a question about the possible use of a brushless motor for my 1:72 scale Alfa and installing it on the stern end cap (on the outside) of the 80mm WTC? would a 750KW brushless motor be adequate for this boat? It would certainly save a lot of problems not having to go through all the shaft design and installing shaft bushing and seals!
Just when I thought I was done with the ALFA builds, well I am back onto the 1;72 scale that was also part of this blog!
Well, this is going to be a big leap! As I stated on this blog about the 1:72 Alfa, I was going to scratch build a WTC (SD) for this boat. I have what might be another one of my big under thought goofy idea!
I have stripped out my original 80mm WTC that was supposed to be for the Arkmodel Type VII boat. I am going to take it from a dual shaft system and convert it into a single shaft WTC. If I can make the conversion from dual to a single, I think the ballast system and the overall WTC will be a good fit for the 1:72 scale Alfa! "Another Experiment"
Randy,Great job Rob! I enjoyed watching your build and the questions you asked were very helpful for those of us still learning.
As for those who comments about accuracy or realism or those with the I can do it better attitude, let them. It’s a hobby, it’s for enjoyment, it’s for learning, it’s for community and I think most of the people on this forum support that and that’s why we come back to see the work of people like you and not just the elite or self appointed elite.
Randy
Just seen your post! Sorry, I am so late in responding! Your words are so kind and FAR to generous. I have so much more to learn about this hobby and the ins and outs about the finishing techniques that are involved. My joy in the building and the mechanics of sub building. A lot of people enjoy making there boats look like they have been at sea for years, and I truly respect those that can achieve this look and with such realistic results. I like the look of before the effect of the elements.
I have made attempts to do a more realistic look on several of my boats. It is certainly a learning process of which I need to spend a GREAT deal more time to achieve. For now I just enjoy the hobby for what it is!
Thanks again Randy,
Randy
Thank you Steve,
It certainly not up to par to the standards that are posted on this forum! And for sure not even close to the sophistication, design, and finish that you apply to your boats.
I know that some really don't care for how I finish out my boats, and that I do not have a true (not even close) representation of a full scale boat, but that is not my forte. And my god, would it not be a boring world if we all did it the same way?! We are all individuals and we should all build on that! "Be Yourself"
Thanks again for the compliment Steve!
"Firemen can stand the heat"Last edited by rwtdiver; 03-16-2022, 02:55 PM.Leave a comment:
Sorry for the video quality!
The above is the running of the Alfa today! Not much to see, only that it does move and is operational. I am very happy with the response other than the small Alfa rudder does not have a great turning radius for my small pool. No big deal, that's how most of my subs have been in our pool.
I am very pleased with the performance, and we can now move to the finish work! As for the finish on my boat! "WHAT EVER FLOATS YOUR BOAT"
NOTE: This build is complete, and I will be moving on! Thank you all for you participation and your input!Last edited by rwtdiver; 03-07-2022, 04:04 PM.Leave a comment:
Today I finished up the final trim work on the Alfa Sub!
I did have to add a small piece of foam to the real starboard side to bring her to level on the horizontal axis! My wife did shoot a video which I will post up soon. The 70mm WTC that I purchased from Bob (Nautilus Dry Docks) worked great. The ballast sizing for the 1:96 scale 3D printed Alfa seems to be right on the money. I set this sub not to go totally under water, but just about 3/4" up the sail. I need to put another good resin coat on the interior of the hull to seal up the PLA a little better. That is an issue with using PLA even at 100% in-fill, it will absorb some water the longer it sits in the water, and this will certainly change the balance and the ballast system.
A good interior hull seal (resin) and a few good coats of primer on the outside prior to final will take care of this issue.
I think the final use of floatation and weights is complete and the boat is just about right in the water photos tomorrow of the boat in the pool!
I did make a change to my RX antenna installation. I moved it to the out side of the WTC, It was just to jammed up on the inside.
Tomorrow will be the final testing, and if all goes well we will head for the finish room!!
Thanks for the info and photos Sam!
For now, I am just going to use the forward dive planes in the up/down movement only.
The Alfa submarine has a very sleek shape, which I really like. Note that its two front dive planes are staggered up and down, as this is the only way they can both retract into the hull. Many Soviet submarines had flaps on their forward diving planes, and the Alfa submarine was no exception.
V
Akula I
Sierra I
Today I got a good start on trimming out the Alfa!
I added some weigh to the bottom of the hull in order to get my CG set up correctly! Then after about 5 trips to the pool and back to the building table, and after adding foam to the upper section of the I think I just about have the boat where I want it. I most likely will be doing yet more minor adjustments tomorrow.
I have found a very good fit on my battery! It's a VENOM 11.1V/3 cell 4000 mAH 20C Lipo battery. It fits like a glove in the lower battery compartment. This battery is one that the RC Cars guys use because of the extra care that has been taken to prevent water or dampness issues.
As we have discussed on this forum and the dive tribe meeting, going overboard on any additional coverings or other forms of keeping the moisture/water out can do more harm than good! Besides if you put the time and effort in MAKING SURE your WTC dose not leak, your water issues are solved!!
"Firemen can stand the heat"👍 1Leave a comment:
