help build a water seal drive shaft
  • aliyesami
    • May 2021
    • 3
    I am following this video to build a water seal drive shaft https://www.youtube.com/watch?v=sjuMFJOgMJU
    but i can't find the parts , i went to the Precision associate website but there they have other companies listed and not the parts themselves.
    also the author is not mentioning the ID/OD of the bushes .
    I need the ID/OD of hollow tube , flange bush the cup seal and the drive shaft dia and if possible one shop where i can buy all these .
    any help greatly appreciated
    Sami
    Your timing is great...... I believe Bob has just started to make complete setups of the seals - check out https://www.rc-submarine.com/props-bearings-seals
      Sami
      Try the McMaster-Carr catalog. That's were I get most of my stuff.
      • aliyesami
        • May 2021
        • 3
        hi David
        i can look at McMaster-Carr but i need the ID ODs of the parts involved , can you give it to me for a 1/8 inch dia shaft assembly ? so the ID ODs of bush, tube and C cup seal ?
          aliyesami,
          As per Tom! I also would suggest going to Nautilus Drydocks for these parts! I use his on all my projects!!
          • aliyesami
            • May 2021
            • 3
            Originally posted by rwtdiver
            aliyesami,
            hi Rob
            can you give me the measurements oif the bush, tube and cup seal please ? i am confused on how to select these based on Bob's video . e.g if the tube inside dia is 1/8 inch then the bushing OD should be little less than that right?
            so if you can give me these three parts from them with the part number i will be grateful
              1/8” used 9/32 brass tube, 1/8” oiliness bushing and 1/8” seal
