Type XXXI U-2540 1:72 Scale Sub Build
    • 12318
    Hi David!
    How did I know that you would be the one with the answers!!:-))
    Thank you very much for the great information. I sure do see the similarities in the photo of Foxtrot and the Type XXl sterns! Thank you for the photos David! Not sure what I am going to do at this point.
    You can follow the German Type-21 imprint on almost all Soviet post-war designs on up to and including their NOVEMBER's. And a big part of our post-war designs was borrowed from the German boats as well.
    Clever people, those Germans... just don't ever let them get on top of you! They love to goose-step along streets not their own. Tulips Shall Grow (Madcap Models No. U1-5) - Bing video
      • 1796
      Thanks for the Bing video!
      Since I have been in the hobby I have certainly noticed how German design and engineering has influenced submarine technology as well as other endeavors they pursued!
        • 2121
        Ultimately the clever little chap from County Clare had the right idea, though.
          • 1796
          I at least have a possible idea as to where I could make the joint separation to gain access to the WTC (SD)!
ID:	150206Click image for larger version
          I would be using the existing SD that I use on my HL Hunley! I could design a gear box similar to (David M.) design. Link up control surfaces with magnets, and use dog bones for the prop shafts!
            • 12318
            I should have known! (I had to look it up). John Holland. Sneaky, Andy... very sneaky.
            And, you're right!
              • 1796
              And, you're right!
              You guys have even got my wife (Masters Degree in Library Science) researching John Holland! She loves history! This guy has lots of submarine history!
ID:	150215Click image for larger version
Name:	John Holland #2.jpg
              Very interesting gentleman for sure!
                • 1796
                I know this subject matter has been covered before! But I am going to be doing a lot brass work on the Type XXl. And I realize the brass will need some prep work before it gets applied to the model and the finishing work after!
                I know that it should be cleaned with laquer thinner, and then a bath in some sort of acid! I am thinking vinegar would do the job!? I have heard that some like to use a more aggressive acid! Any input would be appreciated! Thank you!
                  • 12318
                  Ferric Chloride.
ID:	150858Click image for larger version
                    • 1796
                    Ferric Chloride.
                    Thanks David,
                    I see you have the brass installed before the acid wash?! Is that the best way to do it? I thought I would just dip the entire sheet into a bath of the acid, and then clean it and cut the pieces out and install!?
                      • 12318
                      Thanks David,
                      Using the Ferric Chloride acid to 'pickle' the brass surface is done to enhance the adhesion of primer later.
                      You're going to re-apply the acid (it's job to make the surface pitted to afford better mechanical tooth to the eventual primer coat) after you inlay the brass onto the models surface anyway, as you'll be abrading away excess glue and Bondo after fairing in the brass to the models surface, necessitating re-pickling with acid anyway.
                      Scrub off the photo-resist from the brass -- lacquer thinner and a green abrasive pad -- while it's still in sheet form; inlay the brass pieces onto the model; fair in with glue and Bondo; Abrade away excess glue and Bondo till the inlay work is flush with the models surface; pickle the brass; prim; paint; sing my praises!
ID:	150863Click image for larger version
ID:	150864Click image for larger version
ID:	150865Click image for larger version
ID:	150866Click image for larger version
ID:	150867Click image for larger version
ID:	150868Click image for larger version
ID:	150869Click image for larger version
ID:	150870Click image for larger version
ID:	150871Click image for larger version
ID:	150872Click image for larger version
ID:	150873Click image for larger version
ID:	150874Click image for larger version
ID:	150875Click image for larger version
ID:	150876Click image for larger version
ID:	150887Click image for larger version
ID:	150888Click image for larger version
ID:	150889Click image for larger version
ID:	150890Click image for larger version
ID:	150891Click image for larger version
ID:	150892Click image for larger version
ID:	150893Click image for larger version
ID:	150894Click image for larger version
ID:	150895Click image for larger version
ID:	150896Click image for larger version
ID:	150897Click image for larger version
ID:	150898Click image for larger version
ID:	150878Click image for larger version
ID:	150899Click image for larger version
ID:	150879Click image for larger version
ID:	150880Click image for larger version
ID:	150881Click image for larger version
ID:	150882Click image for larger version
ID:	150883Click image for larger version
ID:	150884Click image for larger version
ID:	150885Click image for larger version
ID:	150886Click image for larger version
ID:	150900Click image for larger version
ID:	150901Click image for larger version
ID:	150902Click image for larger version
ID:	150903Click image for larger version
ID:	150904Click image for larger version
                        • 1796
                        As usual, I am at a total loss for words as to your expertise, deployment of patience, and methodical work to achieve perfection in everything you do!!!
                        Thank you very much again for taking the time to share your fantastic work in description, as well as the wonderful photo guides to show how it's done! I will struggle with frustration, patience, and total wanting to walk away from this project just trying to achieve any portion of the kind work that you do!
                        Thank you again David! You are an inspiration for sure!
                          • 1796
                          Some progress being made on my Type XXXl U-2540!
ID:	151293Click image for larger version
                          The hull is now put together! This boat will not be put to the water! I am going to build the U-2540 as a static display only! I have a lot of brass etching work to do on this mode, and it will be a real learning process for me for sure!
                            • 12318
                            Sail's on backwards. Duh!
                              • 1796
                              Just checking to see who is awake! I knew you would be on it!
                                • 12318
                                #30
                                Check Sat!
