My 3D Printed HL-Hunley Build
    • 2042
    #76
    Looking beautiful, Rob! I can't wait to see it in the water in the final colors....
      Thank you Bob! The Hunley will be the seventh sub I have built to hit the waters surface and move, but it is the first boat I have done that will DIVE! And thanks to you and David, and others for the help it did happen. As I stated above, I do have some touch up that I want to do and then the final coats of clear coat, some water shots, and then the "Sub Wall"! Thanks again to all!!
      Now on to the 1:77 Scale Nautilus!! More fun a head!
        The HL Hunley is finally in her permanent home! (when not in the pool)
ID:	148445Click image for larger version
        I am going to make a framed plaque to go just under her stern! I will be putting the Hunley back in the water today, if the wind subsides a little! I will also try again at a better video of her running in the pool!
          Well the HL Hunley is finished and water tested!
ID:	148470Click image for larger version
ID:	148471Click image for larger version
          The boat did very well! It has a very large turning radius, but keeping the throttle down the rudder was quite effective! I am going to try and get the video up that my wife took, so stay tuned!
            Here is the video that my wife took of the Hunley today!!
            I think this boat turned out pretty darn good! It was my first real diving boat and with help from you guys on the forum (David M, Bob M & others) it was a real success for me for sure! Thank you all for following and for your input! Moving onto the 1:77 scale Disney Nautilus build!!
              • 2042
              #81
              Congrats, Rob! That will be a head-turner at any event you go to. A unique subject and a beautifully executed build.
              • coryhenry
                • Jul 2020
                • 156
                #82
                Great paint job, I can see it rusting in front of me :)
                  Some very last photos of my Hunley! This is her final resting place! (when it's not in the water of course)
ID:	148580Click image for larger version
                  Thank you all for your participation in my build, and of course the compliments!!!!!
                    I had never seen it, Rob. Enjoyed the build.
                      Thanks Casey, but I was trying to put a copy of that build on DrSchmidt build blog because he and you mentioned the Hunley.
                      Stupid mistake!
                      ​​​​​​Rob
