Recent uboat pictures
    I believe you may be confused. Redboat simply asked if he should include the decks on a model depicting war patrol configuration. Answer is no because they were removed from all the war patrol boats. All 61 of the commissioned boats had the deck mounts installed at the factory. These "dotted lines" or" containment framework" as you call them are simply steel tabs with fastener mounting holes cut in them. They were welded to the pressure hull on all the XXIIIs. The 13 early production boats from Kiel were initally equipped the wood decks, since they were still getting the hardwood from the German held S Africa sources. There was no room aboard for stowage so the decks remained ashore and were installed for servicing the boat or cerimonial operation. The 6 boats that actually made war patrols were some the few built in Kiel by the way. The 61 that were assembled in Hamburg were built at remote instalations in sections and sent to Hamburg by rail for assembly. By this time in the war the wood source had been cut off by the Allies and the decks that were already built were utilised by the boats comming out of Hamburg. (one size fits all) I only mentioned hydrodynamics as (one) of the main features of the boats. Actually there were many besides the Walter propulsion system. I would say the 9 second crash dive would be right up top, of course except for the one drawback was it would keep on going unless the planesmen were on their toes. Being faster underwater than up top was a big feature, as well as the "Muffler" that was stuck on the back. The big downside of the XXIII was 2 shots, no spare torpedos and, in port. external loading only. They had to lift the bow out of the water with a crane to stick the torpedos in. Only a 200 n.mile range submerged kept them operationally close. As for the Hai and Hecht's DKM wartime activity,it was nul and short, U2367 (hecht) was sunk after a collision with another u boat during training, May 5 1945 and the U2365 (hai)was scuttled intact on May 8 45. They were both raised in 1956 and re commissioned in the DBM in 1957, as Hai and Hecht. After that all bets are off about deck configguration or sonar arrangement
ID:	83050Click image for larger version
ID:	83051Click image for larger version
ID:	83052Click image for larger version
ID:	83053Click image for larger version
ID:	83054Click image for larger version
ID:	83055Click image for larger version
ID:	83056Click image for larger version
ID:	83057Click image for larger version
ID:	83058Click image for larger version
ID:	83059Click image for larger version
ID:	83060Click image for larger version
        good pic of the hai's HG sonar under the bow, in the sling, at the splash, and in the drydock with the snow on her
ID:	83064Click image for larger version
ID:	83065Click image for larger version
Name:	Uboat plane.jpg
ID:	83066Click image for larger version
ID:	83067Click image for larger version
ID:	83068Click image for larger version
Name:	Sonar on uboat.jpg
          • Warpatroller
            • Dec 2012
            • 90
            #515
            I am definitely confused about where you're getting your information from..
            The Germans never held any territory in South Africa (I'm assuming that's what you meant by "S Africa" ). Maybe you got confused and meant to say North Africa?
            German wood sources were never cut off by the Allies.. The Germans continued to get wood from Norway and from Asia (provided by the Japanese).
            The first 20 boats to be launched into the water all came out of Hamburg, not Kiel. The first being U2321 launched from Hamburg on April 17, 1944. Don't know where you're coming up with this 13 early production boats from Kiel stuff. There were a total of 13 boats to come out of Kiel, that much is correct. The first Kiel boat was not launched until mid October of 1944 (the same time the 21st Hamburg boat was launched). The second Kiel boat launched in November 1944. 48 of the 61 boats were Hamburg boats.
            NONE of the 6 front boats (boats that reached war patrol status) were built in Kiel. All 6 of the front boats came out of Deutscheweft, in Hamburg. Among these were the Hamburg boat, U2336, commanded by Kapitanleutnant Klusmeier. The only XXIII to slam both eels into two unsuspecting ships while on patrol..
            May 7 1945, inside the Firth of Forth, off the coast of Scotland, two British freighters are traveling in the water.. U2336 is in the water.. Farewell and audieu to you fair Scottish ladies.. Farewell and audieu to you ladies of Scotch!
            It was not my intent to get into a posting contest regarding fun facts to know about type 23 U-Boats.
            Modelnut, was the one that asked about the deck planking on war patrol boats. There was no "Plank Blank" order issued by BdU, stating that once a type 23 reached front boat status that the wooden planks can no longer be installed on the boat.
            I wanted to make sure that modelers reading this thread would not think they are doing something wrong or historically incorrect if they choose to "plank" their 23 model. Or feel that the only way they can build a correct model, with deck planking, is if they do a training boat, or early production boat in training phase only. No proof exists to merit a blanket statement, that no plank was ever placed on the deck of a 23 front boat, at any time, during such status.
            If you want your model to depict one of the 6 front boats while it is out on its one or two war patrols, you probably want to leave the planking off the boat. If you want to depict it at port, or manuevering around port, feel free to plank at will! I know I will!
            "Wir kommen ihnen unbekannt."
              ...............................moving right along.................Im fresh out of pictures. Be back when I have somemore.
                Here is a map of Vichy French territories 1942. Madagascar fell to the brits May 5 42 but the rest of the Vichy remained pro German until the Liberation.South cape of Africa was covered by the Royal Navy and no Axis commerce passed from the orient. After D day the Allied blockade of all shipping from, or to Axis powers was in full effect. The 8th AF had blasted the most of the factorys by September 44 and started on transportation targets, railroads, shipyards ect. Sweeden quit dealing with Germany by Christmas, the Dutch had a RR strike and wouldnt send anything to Germany any more, and the only vessels that could sneek out of Narvik were U boats.Click image for larger version
ID:	83156You are correct about the manufacture of 6 XXIII Front boats. my information was a composit of the uboat. net and U bootwaffe.net, that seems to be somewhat conflicting at times and I had jotted notes down on paper as to what boats were where. By the time I had finished I had a page full of shorthand and numbers. Anyway, decks or no on anybodys model makes no differance to me. But now I have to have one in 1/72, after all this hub bub about them. Click image for larger version
                  Amen to that
                    A 3D on the Biber for your perusal.
ID:	83891Click image for larger version
ID:	83892Click image for larger version
ID:	83893Click image for larger version
ID:	83894Click image for larger version
ID:	83895Click image for larger version
                        STAND BY FOR ACTION!........................tomorrow
                          A few more UBOAT pictures.
ID:	84799Click image for larger version
ID:	84800Click image for larger version
ID:	84801Click image for larger version
ID:	84802Click image for larger version
Name:	RO-501 U1224.jpg
ID:	84803Click image for larger version
Name:	Tunis antenna array-U889 rotated manually.jpg
ID:	84804Click image for larger version
ID:	84805Click image for larger version
Name:	U81 small.jpg
ID:	84806Click image for larger version
ID:	84807Click image for larger version
                            • 1647
                            #523
                            Well done Mark, excellent close up of the Tunis antenna, lots of details exposed
                              looks like U 156 skipper picked up a couple sets of tubes and tires for his car and truck, at the Tire Kingdom sale, on the way back from patrol.
                                The last two pictures shows the snorkel head on the U889. It has an extra doodad valve at the top of it.Click image for larger version
Name:	U190 docked JPEG.jpg
ID:	84840Click image for larger version
Name:	U190 side JPEG.jpg
ID:	84841Click image for larger version
ID:	84842Click image for larger version
Name:	U553 ooppss.jpg
ID:	84843Click image for larger version
Name:	U889 aerial  zoom.jpg
ID:	84844Click image for larger version
Name:	U889 rear deck JPEG.jpg
ID:	84845Click image for larger version
Name:	U889 U190 JPEG.jpg
ID:	84846Click image for larger version
ID:	84847Click image for larger version
ID:	84848Click image for larger version
