3D Printed Sub Chaser "194"
    • 821
    Thanks Steve!
    Tomorrow I finish up the primers and sanding. Most likely start the final color finish on Thursday, install the electronics on Friday and total finish over the week-end! This was a fun project, and it did get me off Subs for awhile, but I am looking forward to my first fully loaded Submarine build. Skipjack!
ID:	143972Click image for larger version
ID:	143973Click image for larger version
    This will be my FIRST truly operational diving Submarine! David M. and others will be happy to see this!:-)) I am going to need some help along the way from all you guys!!
    Once you get a diver under your belt you will be a pro. I too have been working on a "target". 1/72 Fletcher. Not 3D printed so my printer can churn out the next sub. Almost finished with weathering.
      • 1936
      Click image for larger version  Name:	20200930_084953_copy_2016x1512.jpg Views:	0 Size:	75.8 KB ID:	143981
      Steve,
      Your "Fletcher" is magnificent! Your modeling skills are exceptional in every aspect in the world of modeling! Thank you for sharing the photo of the Fletcher!!
      "firemen can stand the heat"
        • 1936
        The "194" Sub Chaser project is complete! The final finishing work was completed and all the electronics where installed and tested yesterday.
ID:	144076Click image for larger version
ID:	144077Click image for larger version
        I put the boat to water today, and it performed great! Looked good in the water, and was able to do full right and left hand turns without touching the sides of the pool. Full power was way to much for my pool! This boat is FAST to say the least!!
ID:	144079Click image for larger version
ID:	144080Click image for larger version
        Project complete, and when I can figure out how to upload a video of it running in the pool I will post it up! This boat is 100% PLA 3D printer, 116 pieces went into the build! Thank you for your interest!
        Over and out!!
          • 821
          Turned out great Rob! Looks good on the water. Do you have a YouTube channel?
            • 1936
            Thank you very much Steve! I really had fun building this boat from scratch! And it gave me a little time to pull back from Sub building! Now I will clean up my building area, take a couple of days away from building and get my mind set on my 1:72 Scale Moebius Skipjack!! I most likely will start my own build blog and that way as I have questions (and I am sure I will) It will make it easier for me to follow!
            Steve! I do not have a YouTube channel, but I will be looking into getting that together for sure!
            Steve, I really appreciated you taking interest in my Sub Chaser build!! Thank you!!
              • 821
              Posting videos here is very easy if you first upload to YouTube. Then you just simply copy and past the YouTube link with the video icon here which is found by clicking the underscored A>three dots>film strip looking icon next to the photo icon.
                • 1936
                Steve, Thank you for the information. Looks simple, I will work on this today and get it into motion!
                • coryhenry
                  • Jul 2020
                  • 156
                  The only issue with YouTube is if its blocked by work :)
