Russian submarine id
    Dekabrist D Class
    There were six of these made in the prewar years. The first one was named Dekabrist and it was commisioned in 1934. They were double hull constuction with seven compartments.
    Length was 249 ft. Beam was 21 ft. It was powered by two diesels and two shafts , turning three bladed propellors. Test depth was 295 ft. It could make 14 knots on the surface and 9 knots submerged. It was armed with eight 21" torpedo tubes. Of the six that were made, only two survived the war, one of which, Navrodolets is a museum boat that many of these pictures were taken from. Navrodolets, which was the second of the Dekabrist class had a different conning tower from the first boat.Click image for larger version
ID:	62037Click image for larger version
Name:	d2 narodovolets.jpg
ID:	62038Click image for larger version
Name:	Narodovolets dekabrist.jpg
ID:	62033Click image for larger version
Name:	type d  navorodolets.jpg
ID:	62032Click image for larger version
ID:	62034Click image for larger version
    Dekabrist
Name:	Type D  Navrodolets.jpg
Name:	type d navrodo.jpg
ID:	62045Click image for larger version
Name:	type d navro stern.jpg
ID:	62043Click image for larger version
Name:	Type d navrod stern2.jpg
ID:	62042Click image for larger version
Name:	type d  navrodolett.jpg
ID:	62041Click image for larger version
Name:	type d plans2.jpg
ID:	62040Click image for larger version
Name:	type d plans3.jpg
ID:	62044Click image for larger version
Name:	type d plans.jpg
        Leninets L Class
        These were minelaying submarines that were based on the British L55 that the Soviets recovered and copyed. It was a saddletank design with the mine compartments located in the stern. Twenty five were built. They were 273 ft. long and 23 ft. in beam. Two diesels and two shafts. 18 knots on the surface and 10 knots down below. They were very much disliked by there crews as they were very unstable. Leninet was the name of the first boat of this class. As usual, many variations occured during production.Click image for larger version
ID:	62046Click image for larger version
ID:	62047Click image for larger version
ID:	62048Click image for larger version
ID:	62050Click image for larger version
ID:	62051Click image for larger version
Name:	L-4_Garibaldiec_2 Leninec.jpg
ID:	62052Click image for larger version
ID:	62055Click image for larger version
ID:	62054Click image for larger version
            Shchuka(Pike) sometimes referred to as SC
            There were 88 built and 35 lost during the war. There were three main types.They were all 57 meters long with a beam of 6.2 meters. They all used two diesels for propulsion on the surface with two shafts. They could make 12.5 knots on the surface and 6.3 knots down under. Not as fast as some boats. They had a 300 ft. test depth and were equipped with four torpedo tubes up front in the bow and two in the stern. After the war two were transferred to China.
ID:	62090Click image for larger version
ID:	62087Click image for larger version
ID:	62088Click image for larger version
ID:	62089Click image for larger version
ID:	62091Click image for larger version
ID:	62092Click image for larger version
                Pravda(Truth) or P class
                Three were built in the mid 1930s originally to operate with a surface fleet. After it was realized that they could not keep up with a surface fleet they were then relagated to transport duties. They had double hulls with eight compartments. Because of equipment shortcomings they were the least succesful of the Russian WW2 types. They were considered very slow as well as slow divers, and very rough riders, making their crews very uncomfortable all the way around. It required 20 hrs. to fully recharge there batteries. The two surviving subs had their conning towers rebuilt to look like the later K class. They were 90 meters long with a beam of 8 meters. Test depth was 260 ft. I apologise in advance for the pictures that I am about to post. Good pictures but way too small.
Name:	p1_pravda class.jpg
ID:	62121Click image for larger version
Name:	pravda ceremony.jpg
ID:	62120Click image for larger version
Name:	ss_p-3 pravda class.jpg
Name:	Pravda drawings.jpg
ID:	62125Click image for larger version
Name:	pravda cross section.jpg
ID:	62124Click image for larger version
ID:	62123Click image for larger version
Name:	pravda detailed schem.jpg
                      Malyutka(mite) Also known as little one or baby. Also known as M class
                      There were 111 units built in 4 classes. Most had a crew of 16 to 19 men and most were 37 meters long. The XVs were bigger but only four were made. The idea behind this design was that a small submarine could defend a harbour and coastal area and could be easily disassembled and transported by rail from theatre to theatre. Most had one diesel and shaft. There were 33 lost during the war.Click image for larger version
ID:	62156Click image for larger version
ID:	62162Click image for larger version
ID:	62161Click image for larger version
ID:	62158Click image for larger version
ID:	62160Click image for larger version
ID:	62159Click image for larger version
                        Sorry about the little pictures.
                          S Class unofficially called Stalinettes( follower of Stalin)
                          The most succesful of all Russian Submarines as a class. They sank 82,770 gross tons of merchant shipping and seven warships which makes up a full 1/3 of all the sinkings by Russian submarines during WW2. There were completed 56 units. These boats were a colaboration between German and Russian designers before the war. the dimensions were 77.8 meters long and a beam of 6.4 meters. Two diesels and two shafts. Four tubes up front and two in the stern. 100 meter test depth.Click image for larger version
Name:	type c c-56 sail.jpg
ID:	62166Click image for larger version
Name:	type c in service.jpg
ID:	62167Click image for larger version
Name:	type c  c-56.jpg
ID:	62170Click image for larger version
ID:	62171Click image for larger version
Name:	type c  c-56 sail rear.jpg
ID:	62168Click image for larger version
Name:	type c  c-56  props.jpg
ID:	62173Click image for larger version
ID:	62172 Nice sleek looking boat.
                              K class(katjusa) Long Range cruiser(Kreyser) submarine
                              These were the best operating submarines that the Russians produced. They had seven compartments from inside a double hull. There were twelve built with five lost. Dimensions were 97.65 meters long and 7.4 meters beam. Powered by two 4200 h.p. diesels and two shafts. They could make almost 23 knots on the surface and a solid ten knots below the waves. 230 ft. was there test depth and they packed six bow tubes and two stern tubes.
                              K-21 was inspected in 1944 by a group of american naval engineers. They found her to be inferior in technology to existing Gato class submarines. Diving time was given as 60 sec. Pictures will be contained in the next post.
Name:	K class sub.jpg
ID:	62188Click image for larger version
ID:	62187Click image for larger version
ID:	62186Click image for larger version
ID:	62185Click image for larger version
Name:	k class drawing.jpg
ID:	62184Click image for larger version
ID:	62183Click image for larger version
