Electrical issues
  • secrtwpn
    • Feb 2012
    • 182
    Electrical issues
    Recently, my Blueback ran well at our latest lake outing. However, I had an electrical issue towards the end of the day. So, when I got home, I tried some trouble shooting. When I turned everything on, the ESC would not come up. My system has the Mtroniks Viper Marine 10 ESC and a Sombra SL8 receiver.
    I switched out radios, programmed the SL8 to it, same thing.
    I switched out receivers (one I bought from SubTech, now I believe carried by Nautilus models). The radio is a Vex 6 channel. Same thing, but now everything works intermittently. I do not as yet have a BEC connected. When I wiggle the connections to the receiver, the ESC works for a moment, then shuts down. When I had the Subdriver open, I cleaned up my solder connections on the motor and bought a tool to crimp the bullet connectors.
    Batteries are fully charged
    Could my ESC be kaput?
    Any help would be greatly appreciated!!!!
    Farlan
    • 13649
    Farlan
    So, the receiver bus (as currently configured) is getting all power from the ESC's BEC? That's likely your problem. That BEC is only good for 1.5-2A's which won't hold the load with all servos and other devices working. Put a dedicated BEC in there -- something rated for at lease 3A -- and all will be right with the world again.
    • secrtwpn
      • Feb 2012
      • 182
      I will give it a try! Thanks!
      • QuarterMaster
        • Sep 2015
        • 1235
        Please provide feedback on success as well.
        v/r "Sub" Ed
          • 3670
          Bob made a suggestion (on another forum) to use a separate battery pack to power the RX (and disengage the ESC BEC power). I think that is a brilliant suggestion to eliminate BEC or wiring issue. Farlan, keep us in the loop on what you try!
          • secrtwpn
            • Feb 2012
            • 182
            I will. I'm waiting on a BEC....
            • secrtwpn
              • Feb 2012
              • 182
              So, I finally got my BEC's. Plural because I am saving one for a future project. I soldered it up and hooked it up......No issues with the ESC. And as Merriman said, "all will be right with the world again" As well as can be expected today......
                • 13649
                So …. the system is working OK?
                • secrtwpn
                  • Feb 2012
                  • 182
                  Yes it is!!!!!!!!!!!! Thx
                    • 13649
                    Excellent. And good planning getting that extra BEC for a future project. Never trust a ESC's BEC!
