Electrical issues
  • secrtwpn
    • Feb 2012
    • 182
    Electrical issues
    Recently, my Blueback ran well at our latest lake outing. However, I had an electrical issue towards the end of the day. So, when I got home, I tried some trouble shooting. When I turned everything on, the ESC would not come up. My system has the Mtroniks Viper Marine 10 ESC and a Sombra SL8 receiver.
    I switched out radios, programmed the SL8 to it, same thing.
    I switched out receivers (one I bought from SubTech, now I believe carried by Nautilus models). The radio is a Vex 6 channel. Same thing, but now everything works intermittently. I do not as yet have a BEC connected. When I wiggle the connections to the receiver, the ESC works for a moment, then shuts down. When I had the Subdriver open, I cleaned up my solder connections on the motor and bought a tool to crimp the bullet connectors.
    Batteries are fully charged
    Could my ESC be kaput?
    Any help would be greatly appreciated!!!!
    Farlan
    Farlan
    So, the receiver bus (as currently configured) is getting all power from the ESC's BEC? That's likely your problem. That BEC is only good for 1.5-2A's which won't hold the load with all servos and other devices working. Put a dedicated BEC in there -- something rated for at lease 3A -- and all will be right with the world again.
    • secrtwpn
      • Feb 2012
      • 182
      I will give it a try! Thanks!
      • QuarterMaster
        • Sep 2015
        • 1244
        Please provide feedback on success as well.
        v/r "Sub" Ed
          Bob made a suggestion (on another forum) to use a separate battery pack to power the RX (and disengage the ESC BEC power). I think that is a brilliant suggestion to eliminate BEC or wiring issue. Farlan, keep us in the loop on what you try!
          • secrtwpn
            • Feb 2012
            • 182
            I will. I'm waiting on a BEC....
            • secrtwpn
              • Feb 2012
              • 182
              So, I finally got my BEC's. Plural because I am saving one for a future project. I soldered it up and hooked it up......No issues with the ESC. And as Merriman said, "all will be right with the world again" As well as can be expected today......
                So …. the system is working OK?
                • secrtwpn
                  • Feb 2012
                  • 182
                  Yes it is!!!!!!!!!!!! Thx
                    Excellent. And good planning getting that extra BEC for a future project. Never trust a ESC's BEC!
