Blueback trimming
  • secrtwpn
    • Feb 2012
    • 182
    Blueback trimming
    After several weeks of gnashing of teeth and threatening to shove it down the garbage disposal, I believe I have reached trim I am happy with ! Thanks to Dave and Bob for the pointers in the past! Click image for larger version
ID:	136315Click image for larger version
    • 13632
    Huurrah! Once you get to play in open water, it will all be worth it. Keep us informed.
    • secrtwpn
      • Feb 2012
      • 182
      Next lake day is Feb 8......
      • secrtwpn
        • Feb 2012
        • 182
        Here are pics of her underway.... Click image for larger version
        Farlan CluttersClick image for larger version
          • 3670
          I am bummed I was not able to e there to see you run. Looks like you have it dialed in, how did it run?
          • secrtwpn
            • Feb 2012
            • 182
            She ran well. But I had transmitter issues. Don't know if it's the tx battery or the receiver. My receiver is a Sombra SL 8. Does this stuff ever stop???????!!!!!!!!
              • 13632
              No! (in the shouting voice of Bruce Willis) "Welcome to the party, pal!"
              • secrtwpn
                • Feb 2012
                • 182
                Im going to try a different radio and then change out the receiver........
                  • 13632
                  Wrong! First rule of trouble-shooting is to change only one condition at a time, and only the most likely cause of the trouble. Test, evaluate, and if fault remains make a second condition change. Repeat. Stir well. Do not take with alcohol.
                  You do two changes at a time you won't know which of the two was sour and the other good -- you learn NOTHING! Occam's Razor suggests addressing the most obvious fault first. I recommend you pick on the transmitter first. If it ain't the transmitter, only then **** around with the receiver.
                  Not My First Rodeo
                    • 2503
                    Might be either of those- could be a power supply issue. What BEC are you using?
                    I once had an intermittent fault on a sub, that was a so and so to isolate, it would randomly affect the ballast control, turned out toe a duff signal wire on the ESC that controlled the ballast pump, and the fault was inside the esc's board, so it was I spy with my little x-ray eye.
                    • secrtwpn
                      • Feb 2012
                      • 182
                      BEC???????? UHHHHHHHHHHHH dunno. Using an Mtronics speed control............Well, when it stops working, the only thing I have operating is the auto depth thingamajig (ADF 2). I recharged the TX battery and ran it down to almost zero. I then turned on the sub and it was OK for a few minutes, then it went dead. The TX battery then read 60%. So I dunno. I'm gonna try another transmitter. Never had this before............
                        • 13632
                        It's an angle-keeper (working the stern planes if you have it hooked up right). It's hooked up to a servo, so that's drawing current too. Even when operating the two devices will draw considerably less than an Ampere, and the receiver is drawing current as well -- maybe 500mA's. Regardless, the three devices are pulling current well below the rating of the MTroniks BEC. So it's not likely a BEC issue.
                        That said, the other servos and devices will up the current draw off the receiver bus, and that may tax the BEC to the point if skittish operation. Bottom line, get a dedicated BEC in there rated for at least 3 Amperes.
                        Get a fresh battery in that transmitter, bang it up and test. Transmitter circuitry is usually rock solid -- it's almost always the battery that lets you down.
                        You might consider taking the red wire out of the lead between ESC and receiver and plugging in a receiver battery. If things work fine after that then you have a bum MTroniks BEC.
                        • secrtwpn
                          • Feb 2012
                          • 182
                          Thanks for the info. How is the BEC connected?
                            • 13632
                            Your receiver has many unused input ports (it's an 8-channel unit, right?). The BEC input wires go to the battery, and the BEC's output plugs into one of the unused ports which puts the BEC's five-volt supply to the entire receiver bus. Remove the red lead from the ESC's receiver lead so you isolate that devices weak-ass BEC -- you don't want it screwing with the dedicated BEC's operation.
                            • secrtwpn
                              • Feb 2012
                              • 182
                              Thank you sir!
