Anyone have experience with Graupner Brushless motors?
  • Stephen Vick
    • Nov 2018
    • 67
    I've recently ordered a pair of Graupner Speed 500 brushless motors (Christmas sale couldn't pass on it) Supposedly they are high torque low RPM . I intend to install them in a Robbe Type VII. I will be using a Robbe F 14 twin stick for dual control, Anyone have experience with these? Can Anyone recommend an ESC? Thanks in advance!
    • 1982
    I'm carrying the new MTroniks reversible (true reversible, mind) ESC's for brushless motors. They're not cheap, but they're beautiful units. $79 each with 30A capacity. I'll be creating the product page in the next couple of days.
    • Stephen Vick
      • Nov 2018
      • 67
      That looks like what I need. Its the reversible (true reversible) bit that has been the sticky wicket.
      • gantu
        • 389
        Hi for the robbe type VII is this motor very good https://engel-modellbau.eu/shop/en/E...or-400-kV.html
        and this esc is Programmable https://hobbyking.com/de_de/turnigy-...2-6s-opto.html
        https://oscarliang.com/blheli-32-overview/
        Gantu
        Regards Gantu
        • Bob Gato
          • 873
          OK I'll give... what is true reversible? Rotation? as opposed to switching the wires? Programmable- punch, brake, rotation, % reverse,timing?
          • gantu
            • 389
            Regards Gantu
            • gantu
              • 389
              https://oscarliang.com/blheli-32-esc-fc-passthrough/
              Regards Gantu
              • Stephen Vick
                • Nov 2018
                • 67
                Good question; what I have found is that most Brushless speed controls have a "Braking" function which serves as reverse. This setup gives only partial reverse power or reverse for only a short time. I read True reverse as full power for as long as one needs it. As a former ship driver, I like to have full function on twin screws, to execute twist maneuvers etc... finding the esc that gives me that has been difficult.
                • gantu
                  • 389
                  Hello i do use this esc´s and there do fully reverse and forward continuous so had never problems.
                  Regards Gantu
                  • Bob Gato
                    • 873
                    Any ESC worth it's salt would be programmable-with at least reverse(at various percentages) and braking that can be programmed to "no Brake" also punch (start force), rotation, timing, and Low Voltage Cutoff threshold for Lipos. Neutral range, Overtemp shutdown, reverse polarity protection and short circuit protection would also be nice.
                    • Stephen Vick
                      • Nov 2018
                      • 67
                      Indeed you are correct. I have loads of experience using brushed motors and esc. Not so much with brushless, except a wee bit of mucking about with airplanes. I think I have narrowed the search for esc . The next question is; are the graupner motors low speed enough? or will I need a gear or belt drive reduction? I thought perhaps I would give them a go direct drive and see how it goes. They advertise them as low RPM , high torque. However, I've never seen a brushless motor that wasn't insanely fast... Its all new territory for me.
                      • Bob Gato
                        • 873
                        Stephen, The web site doesn't say what KV they are only that they are high torque/low RPM...I'm sure you'll be fine..If you get a read on the KV rating, multiply that number by the voltage you are using and that will give you the unloaded max RPM. Subtract 20% for inefficiencys and that should be the max RPM your prop will turn at...
                        Are you going to run twin motors or split the output?...if twins, I should say (you probably know this) you can't run two brushless motors off one ESC-must have two.
                        • Stephen Vick
                          • Nov 2018
                          • 67
                          I’m running twin with 2 ESC. I have a Robbe F14 with twin stick standing by.
                            • 3670
                            I am just messing with brushless right now.
                            I bought these
                            All about R/C hobby, model submarines and boats, RC systems, accessories, batteries and other useful hobby gadgets. Fast shipping.
                            others use it at the pond I run at so, I am trying it out.
                            • Bob Gato
                              • 873
                              So Stephen, sounds like you are going to independently control each motor. I don't know how much distance between props and how long the boat is but chances are that differential thrust isn't going to do much for you. Consider running a wye lead to both ESCs from one channel and use the other channel for something else...
