A mini lathe
    • 2848
    A mini lathe
    I thought some folks might find this a useful tool! The price is right too! https://www.wdivorce66.com/products/...EB8Ky2vC0w7LYU
    • 3547
    $69 not a bad price for a simple wood lathe!
      • 12318
      Thanks, Mike. Very good steer. Just ordered mine.
      • george
        • Dec 2010
        • 727
        Now with your knowledge and experience, can you design a simple basic mini cheap lathe for metal use with the capacity to turn End Caps and you know how big those can be.
          • 12318
          • george
            • Dec 2010
            • 727
            WOW!!! I have to ask though, for non metal turning it looks Good BUT to work with metal, I don`t see how you can safely work with cutting bits in your hands???????????
              • 12318
              Slow speed, very soft metal (white-metal, machine brass, etc.), sharp tool, tool rest right up against the work. Band-aids at the ready! When work is completed, inventory fingers. OSHA can kiss my fat, pimple-encrusted, diabetic ass!
              • george
                • Dec 2010
                • 727
                Get it Be Dam Careful BUT can be done. I see, said the blind man to his deaf wife.
                Your drill being used, the chuck 3/8" or 1/2" ? Is one better than the other, why?
                My mind has a brain cramp, the device that controls the power/speed is called?
                  • 12318
                  3/8" chuck. Tapered shank. Make sure the bearing is tight.
                  Dremel AC speed controller. A generic version is also sold by Harbor Freight. And buy the foot-switch -- makes life easier.
                  • george
                    • Dec 2010
                    • 727
                    ah
                    Thanks Again for the lessons. "Make sure bearing is tight"?????? Sorry do not know what you refer to.
                      • 12318
                      ah
                      The spindle the chuck is attached to; or, if you will, the shaft that leads from the motor/belt pulley down to the chuck. The spindle/shaft Is usually supported by one or two roller/ball bearings (or a big Oilite in cheaper units). If, over time, and/or hard use, ware increases the non-interference fit between bearing and spindle/shaft, it will cause the work to vibrate laterally to the tool pressed against the work. Setting up -- under the right conditions of load, feed-speed, tool pressure and angle, and RPM -- a resonate vibration that will evidence on the work as 'wavy' lines. Chattering. Change any one of the variables and you alter the amount of vibration. Tight bearings mitigate all this happy horse-****.
                      Loose bearings breed vibrations. Duh!
                      Don't make me come over there!
                        • 2121
                        $69? Paid about that for this one. Almost thirty years ago mind.
                          • 12318
                          You're killing me, Andy! What a beauty! As long as you can still tighten the gibs who cares how shop worn that best is.
                            • 2121
                            Only the cross feed screw had any appreciable wear, as the machine was primarily used for facing operations. A machine like this will last for generations in a home workshop.
                            • george
                              • Dec 2010
                              • 727
                              Thanks for ALL the tips. Without taking apart a drill, how do you check for tight bearings?
