Alfa bow planes
    • 13980
    Originally posted by Scott T
    Thanks! Nice pictures of the mechanism.
    No Sketch off? :(
    My thought was a single actuating rod that moved forward and back for pitch control and rotation for extending the flippers (planes).
    The gear rotation would push the planes out with cranks on a crankshaft.
    When the planes were extended the rod would move forward and back to pitch the planes.
    The gear would un-mesh in the up and down position of the plane travel and would not retract till rod\planes came back to centered gear position.
    Bingo.
    • Scott T
      • May 2009
      • 414
      That was fun. I got a bingo. Thanks.
      • george
        • Dec 2010
        • 731
        Hi Scott T
        Any chance you could draw that out in darker ink? Also hard to read the writing. The image is not dark enough to be seen easily for me with glasses on.
        Also Thank You for stepping up with a design mechanism!!!!
        George
          • 13980
          Originally posted by george
          Hi Scott T
          George
          That's right Scott! Hand it to him on a platter or you're not living up to you obligations here. You cad!
          No good deed goes unpunished.
          The Slacker
          • george
            • Dec 2010
            • 731
            ouch! Tough to ask to see better, Wait till you youngsters get old and eyes act up!
              • 13980
              Welcome to Thunderdome.
              Master/Blaster
              • Scott T
                • May 2009
                • 414
                Maybe later. Wheels off the tractor needs a fix.
                • Bob Gato
                  • 898
                  You picked a fine time to leave me loose wheel!
                    • 13980
                    LOL! (Ellie had to explain it to me). Very good, Bob.
                    • Scott T
                      • May 2009
                      • 414
                      Wheel is still loose. Sketch attached.
Name:	sub plain mech-.jpg
                        • 13980
                        Beautiful, Scott. Clean, crisp, simple. KISS.
                          • 3752
                          Love your mind Scott!
                          • Bob Gato
                            • 898
                            Consider using a modified version of the Bob Martin/Ed Tordahl linear servo mechanism-this way you wont have to articulate the connecting rods..
                            • george
                              • Dec 2010
                              • 731
                              Question about Bow planes support rods. I think the norm is to use 1/8" brass here in the West. Anyone have running experience with these? I was wondering IF because they are exposed with no support like the stern planes have. Has there been cases of shafts being bent while in normal use? IF so that would call for a thicker shaft if the bow planes are to be retractable and be able to be pivoting.
                              Your thoughts?
                              • type7
                                • 198
                                #30
                                Yes the shafts of the bow planes get bent and sometimes the mounting gets torn loose of the bulkhead. The question is not if the shaft is strong enough but what do you want to give out when the bow plane strikes a hard object?
