DeBoers Seaview Restoration
    • 13996
    Originally posted by Groot689
    Perfect. Thanks David, ah er your Highness. This is what I need. My life has meaning once again.
    I found the deck and side-walls to the Observation Compartment, I'll cast those up over the weekend for you. Still can't find the sail tool (likely lost in the flood of a few years back), so continue on with Dennis' original.
    • Groot689
      • Mar 2016
      • 135
      Thank you! Can't wait.
      • Groot689
        • Mar 2016
        • 135
        I have finally been able to continue my work on the Seaview sail by filling cracks, sanding, adding new doors and sail details. I have applied a quick coat of primer and temporarily attached the dive planes. Looking much better I think.
          • 13996
          Parts coming your way tomorrow. Sorry about the delay.
          • Groot689
            • Mar 2016
            • 135
            No problem! I have not been able to get back into the workshop until last weekend so my progress has been slowed somewhat. Your parts have already made a big difference on the sail.
              • 13996
              Not to poop all over your parade, but that 'brinicle' you mounted in the bridge: Its not a brinicle. It's an ashtray! (ducking for cover).
                • 3766
                Already looks much better!
                • Groot689
                  • Mar 2016
                  • 135
                  See, I actually knew that. Richard Basehart was an avid smoker and quite frankly, I had trouble finding room for a brinicle since the layout of the DeBoer bridge is different from Mobius etc. Besides, its what Basehart would want.
                    • 13996
                    I'm an ass …. can't even spell it right: Binnacle! I'll see if I can't find a replacement for that ash-tray you got spoiling the otherwise good looking bridge.
                    • Groot689
                      • Mar 2016
                      • 135
                      Well, I'm back. My new job has been kicking my butt and I have had to set aside my hobby projects (gasp, I cant believe I just said that) for the time being. However, work on the Seaview restoration has officially resumed. More to come...
                      I have started working on the stern while focusing on the fins and control surfaces. First, I have removed the damaged fins and removed old epoxy etc with my Dremel. I block sanded the exterior hull both top and bottom and geez... this primer/gel coat/ kevlar impregnated coating is tough. I was able to get rid of some imperfections but revealed even more. Next, I used a two part epoxy to bond the control surfaces on the fins and will follow up with several layers of Evercoat and lots of sanding.
                      • Tugfan
                        • 178
                        Garry Kerr and his politics makes me sick to my stomach.
                        • Tugfan
                          • 178
                          Anyone ever notice that the periscope on Seaview was
                          before the hatch in the control room, but was behind the sail hatch
                          on the sail?
                            • 13996
                            on the sail?
                            Any attempt by the viewer to resolve physical paradoxes between miniatures and sets of an Erwin Allen production learn the true meaning of frustration.
                            I know!
                            Guys like Dennis DeBoer, Rick Knorowski, Fred Barr, Gary Kerr, Paul Lubliner, and myself have suffered for years trying.
                            • QuarterMaster
                              • Sep 2015
                              • 1244
                              I know!
                              Hey!
                              If we're gonna suspend belief....go ALL the way!
                              The SEAVIEW was a girl ahead of her time!! She used PHOTONIC MAST's" !!
                              Now be quiet so I can get back to my WIP sub which was miniaturized to 3 microns and injected into a human body. Sheeez
                              BTY, this is a great shot Dave. Cleaned up resolution wise, and removal of the pool filter gives it a show (story) quality!
                              v/r "Sub" Ed
                                • 3766
                                #30
                                Played a little....
Name:	Skipjack and Seaview 02.jpg
ID:	135524Click image for larger version
Name:	Skipjack and Seaview 01.jpg
