Vacuum Former idea
    • 2848
    Vacuum Former idea
    This little guy looks just the ticket for some projects.
    see https://www.mayku.me/
    A bit pricey at $690 but interesting concept.
    • 1777
    I think I picked up a little vac former from MicroMark for something like $80, but I can't remember. Their site looks like it's down right now or I'd check. The platform was only something like 6"x6", but more than adequate for what I use it for...
    • Ken_NJ
      • Sep 2014
      • 773
      I made my own, mostly from material I had around the shop.
        • 12314
        Like all model making techniques, vacuforming has its applications. The trick is to employ the correct technique for the job. Here are some jobs where vacuforming or heat-forming was the right choice:
        A job I did for IBM. It was on display at the air and space museum (Smithsonian) for about a year.
        Improving the Trumpeter 1/144 KILO kits with a well for the messenger buoy
          • 12314
          I enhanced the Williams 1/12 KAIRYU kit with this vacuformed deadlight 'funnel', and hatch well.
          And some SF stuff just form me.
          • bourdonnais
            • Aug 2018
            • 4
            Can we expect enough mechanical resistance with this technic to realise a missile deck (about 1 meter lengt) and a sail of a submarine?
              • 12314
              Ah …. what?
                • 2121
                I think he is asking if vacuum forming will be tough enough for a 3 foot long missile deck with sail for a model submarine.
                • bourdonnais
                  • Aug 2018
                  • 4
                  Yes indeed, sry for my english
                    • 12314
                    Now I understand you. And thanks to the Boss-man for clearing that up.
                    To answer: Entire hulls have been vacuformed from polystyrene and ABS and have been found to be most suitable as hull and sub-structure elements. A (now defunct) French outfit once offered a big vacuformed TYPHOON. And the classic 32nd Parallel, 1/32 Type-23 kit was mostly vacuformed, as was the old SubTech 1/60 ALBACORE and 1/32(?) MARLIN. I've had practical experience with the last three and found the structures to be sound. Good stuff.
                    Once, I even made the entire structure of the TOS ENTERPRISE from vacuformed pieces:
                    As to your missile deck: Sure. Why not?
