Gangelt Germany 2026
    • 1640
    Second try, the first post wasn't approved due to much pictures at once,
    This event was during three days, we arrived on friday,
    Click image for larger version  Name:	20260502_103632.jpg Views:	15 Size:	40.7 KB ID:	195138
    Click image for larger version  Name:	20260502_103719.jpg Views:	13 Size:	43.1 KB ID:	195139
    The pool which was used during the event, a shallow part, about 1,5 mtr deep and a deep part, about 3 mtr deep.
    Click image for larger version  Name:	20260502_095013.jpg Views:	13 Size:	30.7 KB ID:	195140
    Click image for larger version  Name:	20260502_095039.jpg Views:	13 Size:	40.3 KB ID:	195141
    David is gonna love this one, a Albacore big scale, weight about 35 kg, max propulsion power a staggering 1000 watt !!!, talked with the builder, he wasn't able to run at full power because the pool was too small, also included a arduino controlled depthsystem when hoovering the boat.
    • 1640
    The front part, holding the arduino with depthkeeper, and a kind of circuit which is being used to monitor the boat, giving him information about the used power, dive time and much more.
    A fast acces point to adjust the depth keeper, no hassle needed to open up the complete hatch,
    This contained the charchingsystem, he only needs to open this hatch to charge the boat.
    Manfred,
      • 1640
      Those are the stands during the event, lots of differend models present.
      Click image for larger version  Name:	20260502_103452.jpg Views:	0 Size:	46.1 KB ID:	195149
      Click image for larger version  Name:	20260502_103501.jpg Views:	0 Size:	49.5 KB ID:	195150
      Click image for larger version  Name:	20260502_103515.jpg Views:	0 Size:	46.7 KB ID:	195151
      Click image for larger version  Name:	20260502_103528.jpg Views:	0 Size:	48.1 KB ID:	195152
        • 1640
        Last batch of the stands.
          • 13940
          Neat!
          Typical European over-engineering on display here. You guys are nuts!!!
            • 1640
            Yup, those germans go for speed and complexity, learned a lot from that old guy (80 years) who build the Albacore.
            I do have more pictures made,
            The same guy of the Albacore has also build a big scale Seehund, most of their subs are build with those Engel based piston ballasttanks, adding more complexity to the boat.
            Common in use is the bajonet lock system, batteries are placed in the keel, just like the original.
            When using a piston tank you need to know at which position the plunger is, to counter that they are using Hall sensors on both ends of the piston tank.
            To make the Hall sensors more accurate, he placed a ring of magnets on the plunger, so it doesn't matter if the plunger will rotate during action, talking about over enginering!!!
            To make the puzzle complete, he also made two torps with counter rotating screws, the secret is how to seal both shafts, he is using both O rings and lipseals
            Next question is, how to start those torps, he used a extra 5 channel reciever to activate them, when activaded they only run straight, no steering and depth keeping, they are balanced just afloat
              • Oct 2017
              • 1038
              Loving it! Thanks for posting, Manfred!
              Jörg
                • 1640
                Some underwater pictures i borrowed from out dutch forum,
                Click image for larger version  Name:	IMG_0105.png Views:	0 Size:	19.3 KB ID:	195197
                A rc F35 for flying underwater, made by one of our dutch forum guys
                Click image for larger version  Name:	IMG_0106.png Views:	0 Size:	17.7 KB ID:	195198
                A kind of flying hamburger, used lexan to project lights during the evening, unfortunally there was too much light during the daytime
                Click image for larger version  Name:	IMG_0109.png Views:	0 Size:	20.3 KB ID:	195199
                From the same guy at out dutch forum, a Grumman Avenger.
                Click image for larger version  Name:	P5021205.jpg Views:	0 Size:	46.4 KB ID:	195200
                A Forel submarine build by one of the Germans
                Click image for larger version  Name:	P5021258.jpg Views:	0 Size:	52.2 KB ID:	195201
                Some story on this Type XXII.
                Click image for larger version  Name:	P5021298.jpg Views:	0 Size:	53.1 KB ID:	195202
                Mammals in the shape of a orca, very good turningradius and high speed underwater, he made a few times a jump far above the surface.
                Click image for larger version  Name:	Spirou Gangelt.png Views:	0 Size:	20.5 KB ID:	195203
                My spirou submarine caught during action, still learning how to drive her properly
                PS, Hmmm, some pictures are really small, follow this link for better pictures, https://www.modelbouwforum.nl/thread...zondag.295448/
                  • 3666
                  Mystified by that hamburger submarine.
ID:	195215 Front ducted drive
