bow plane retracts
  • fhouldson
    • Feb 2013
    • 45
    #46
    Will let you know in a little while. Going to do both test in about 10 min
    • fhouldson
      • Feb 2013
      • 45
      #47
      Test 1- Red Green Red Green Test 2- Red Green Green Green
      • fhouldson
        • Feb 2013
        • 45
        #48
        found and old Jr Rx and hook it up. Everthing works every time I turn it off and on, no glichs.
        • fhouldson
          • Feb 2013
          • 45
          #49
          need to know if I need to get a different rx or is there a fix to the one I have.
            • 13986
            #50
            A fix to your existing receiver is not assured and will take a long, time if it is possible -- likely fix would involve a re-write of the units micro-processor code, and only if there's an over-write capability. Cheaper and more immediate to get a new receiver.
            • fhouldson
              • Feb 2013
              • 45
              #51
              will the rx that sub dive sells work well in the sub ? if it does I'll order one of those. let me know . Thanks for all the help
                • 13986
                #52
                sub dive?....................
                • alad61
                  • Jan 2012
                  • 476
                  #53
                  If the JR rx works then why not use that? I run all my subs with a JR rx pretty much glitch free with the adf2. The only time I had your issue was using a corona rx.
                  Cheers,
                  Alec.
                  Reality is but a dream...
                  But to dream is a reality
                  • fhouldson
                    • Feb 2013
                    • 45
                    #54
                    The jr is to big for the 2.5 sd. My mistake David I ment sub-driver from caswell
                      • 13986
                      #55
                      The line of receivers we sell are (formally) the Sombra Labs SL-8 and Lepton-6. Additionally we are bringing back the original WFly eight-channel receiver. Unfortunately this great line of Sombra Labs receivers are no longer available on 75mHz, so we are going back with the WFly receivers ... once we get the manufacturer to re-write the code that will make them work with our ADF fail-safe feature. But, yes, all three type receivers we sell (or have sold) will fit even the smallest SD cylinder.
                      • Buellman1
                        • 93
                        #56
                        I put shims in to space the servos outward a bit and carved the tray out some. But I've got a JR scanselect rx to fit in the gato SD tray. Click image for larger version
ID:	77163I know its not the greatest photo depicting rx install, but it shows it in there.
                          • 13986
                          #57
                          Take your receiver out of the plastic case, and put the board into some heat-shrink -- that will reduce the 'thickness' of the receiver package.
                          • fhouldson
                            • Feb 2013
                            • 45
                            #58
                            I will try that. Will let you know how it turns out.
                            • KevinMc
                              • 305
                              #59
                              @fhouldson I'm confused - your results don't line up with any of the operating modes in the code. Is the first "Red Green
                              " in each of your tests actually "Red + Green"? Regardless it certainly seems that you're up against an Rx/ADF2 compatibility issue. Also, after you made the ADF2 pitch control connection in Test 2 did you have control of the servo?
                              I've been working on a fix for this type of problem but the solution is still a way's out. If you can squeeze in another Rx I'd definitely recommend going with that solution.
                              KMc Designs
                              • fhouldson
                                • Feb 2013
                                • 45
                                #60
                                The first test was red-green pause red green. test 2 was red-green-green-green and the servo did work. Put a jr rx in and everything worked fine for quite a while. thought I had the problem solved. Now wiith the jr rx it's doing the same thing
