bow plane retracts
    • 3686
    RTV silicon - as a tip, take extra time to shape the foam to fit closer to the hull, avoiding air pockets if possible when you make the final placement.
      • 13743
      ... words from one who knows!
      • fhouldson
        • Feb 2013
        • 45
        got the ballast kit for the gato from caswell. not for sure where the 6 pieces go. On bottom or sides. I'm thinking bottom and foam on the sides. All so not sure where pink foam goes. The 6 pieces are black with what looks like bird shot in it.
        Please let me know. Thank you
          • 13743
          Start with three of the weights, situated in the center. And, yes, they go in the bottom of the hull. The foam, is equally spaced longitudinally on the sides of the lower hull. The trick is to place the top of the foam even with the boats designed waterline.
          Make your initial installation take pictures and we'll guide you in for a safe landing.
          • fhouldson
            • Feb 2013
            • 45
            put foam in hull. the weights are just sitting ther for now. need to know if is alright to grind them down a little. wtc woun't fit all the way down the way they are. Here' picsClick image for larger version
ID:	76624Click image for larger version
              • 13743
              sure, grind away
              • fhouldson
                • Feb 2013
                • 45
                do I need to redrill the holes on the lower hull that the weights are going to cover?
                  • 13743
                  no........................
                  • fhouldson
                    • Feb 2013
                    • 45
                    Got all my foam in and my weights epoxyed in. Hopefully weather permiting going to my sons house and use his pool to balance the sub.Will let you know how it turns out.
                    • fhouldson
                      • Feb 2013
                      • 45
                      would like to know the reason for balancing sub below surface instead of at the water line on surface
                        • 13743
                        Because I said so, damit!
                        You people!
                        first you want to work out the amount and longitudinal location of the foam within the hull, with the ballast tank full, so that the boat at rest is on an even keel and just an inch of sail sticking out of the water. Proper submerged trim.
                        Then, with the ballast tank dry, you will move foam vertically to achieve the correct surfaced waterline.
                        Done! Happy trails! Kiss the girl. Go home happy.
                        • Anuci
                          Banned
                          • 165
                          Very nice job you've done on the model. neat and clean finish. Don't sweat the small stuff, adjustments to the weight and foam distribution may be needed from time to time anyway. It's not an easy task, but you've done good. Enjoy!
                          • fhouldson
                            • Feb 2013
                            • 45
                            David, Thanks for the reason on balancing.
                            Anuci, Thanks for the comments. Doing the best I can. Only have built warships and frieghters, subs are a hole different breed.
                              • 13743
                              Because it's easier that way.
                              • fhouldson
                                • Feb 2013
                                • 45
                                #30
                                been gone for a while. back working on sub again. got a little problem. when I turn everything on for the first time everything works fine. when I turn it off and then back on the elevator and ballast do not work. I leave it turned off for about 10 min then
                                turn it back on everything works again. Everything is hooked up right and full battery. It has the adf2 and lipo guard in it. any ideas.
