FUTABA PK-FSM 75mhz MODULE FITS WFLY 8 Channel
This is a sticky topic.
    The Futaba PK-FSM module can be purchased from TAMIYA MODEL for $67.45. It's great advantage is that the crystal frequency can be changed without removing the module from the radio, unlike the Hitec module.
  • george
    • Dec 2010
    • 731
    Hello Mike
    Please help me understand this. If I was to buy your WFLY 8 channel Transmitter and this Futaba PK-FSM 75mhz module. Could the radio combo then be able to control my Futaba FPR127DF 75mhz FM Dual Conversion Receivers that I have on a few different channels?
    Also to use in a SMALL WTC this radio could be switched over so that I could use your SMALL brand of receivers on it by myself, how would that be done?
    Thanks Mike.
    George
    • KevinMc
      • 305
      Yes - This combination will work with any negative shift receiver (including Futaba, HiTec, and Sombra Labs to name a few) and in my experience is more flexible than the venerable Polks Tracker III.
      You just set the dials on the back of the module for what ever channel you want, load up the appropriate model from the model memory in the radio and you're set to sail.
      KMc Designs
      • george
        • Dec 2010
        • 731
        Hi Kevin
        George from Hamilton Mountain. Thank You for explaining the radio for me. Now I know what radio to plan for to clear up my radio mess. I have a fair amount of Futaba FPR127DF 75Mhz FM Dual Conversion Receivers and this radio will control them without any problems.
        Great to know.
        George
        • PhilC
          • Feb 2017
          • 5
          I understand that I came to this party very, very late, but is this transmitter and Futaba 75 MHz module still available?
            • 3742
            Only second hand. Futaba does not make this anymore for our frequency.
            • PhilC
              • Feb 2017
              • 5
              Thank you. How about the transmitter, ebay also??
                • 13955
                Yeah, today that's about your only recourse. But, there may be hope in the wings .... there's the possibility that Bob may be able to secure some r/c systems that are submarine friendly. Nothing for sure yet, and the deal is still in the works. But, the problem of unavailability is being worked on. Stand by.
                  • 2043
                  I have a bead on a decent-sized a lot of four, six, and nine channel Futaba radios. Still working out the details, but if you are in immediate need, let me know and I'll get it figured out for you. Brand new and still in the box.
                    • 13955
                    Sign me UP!!!!!
                    • PhilC
                      • Feb 2017
                      • 5
                      Thank you all for your responses!! I am not in immediate need as I have a couple of Futaba 75MHz 4 channel sets. My current project is a dynamic diver, so I am good for now. BUT I do want to build a model with more features and will be in the market for at least a 6 channel, but I am drooling over the concept of a 9 channel set!! :)
                      I also recently realized that the receivers that came with my 4 channel transmitters are actually 7 channel receivers. So perhaps if I can find the right transmitter I can more fully utilize my existing gear?
