I have a new AD2 purchased from Nautilus Drydocks. The AD2 is mounted to the aft equipment tray of my R&R WTC and lays alongside the ballast pump.
Upon powering up my WTC, the AD2 initially seems to function properly. The aft planes move smoothly to counter rise and fall of the back of the sub. The aft dive planes override feature works okay. Upon activating the ballast pump, the aft dive planes exhibit moderate jitters. Operating the twin brushless motors causes more pronounced dive plane jitters. I understand that this is normal for the AD2. It is said that the AD2 is sensitive to motor vibration.
The problem is that after running the brushless motors (sub is in the water), the aft dive planes override feature no longer works. Disconnecting the subs battery and re-connecting brings back the rear planes override, only to have it stop working again after I run the drive motors. Not good as I cannot program a working FAILSAFE command to cause the rear planes to rise in an emergency. Anyone with experience, hopefully a cure?
BTW, I’ll be at Subfest with this boat.
See you in September :-)
