FrSky Tandem Dual Frequency Transmitters
  • biggsgolf
    • Jan 2020
    • 1036
    Would this System technically work using 2.4Ghz alone when sub is submerged? I would need to depend on the RX antenna protruding above the water when sub is submerged. Is there a way to extend the 2.4Ghz with RG178? Do the RX's have IPEX connectors? Just been on my mind, hope this makes sense? I would like to employ this system for it's many capabilities.
    • biggsgolf
      • Jan 2020
      • 1036
      Yes, but that's not a tandem receiver
      • biggsgolf
        • Jan 2020
        • 1036
        Need to know if it will work
          Click image for larger version  Name:	LCCA30053-FT6_250x250_View1.jpg Views:	1 Size:	9.7 KB ID:	180596
          Instead of an ipex connector how about installing a male- female connector on the tip existing antennae?
          L-com’s SMA male connector for RG178 coax uses a crimp/solder attachment method. This SMA connector is one of the many RF coaxial connectors in L-com’s product line up and like all our products, they will ship the same day. Our SMA male connector operates up to a maximum frequency of 1 GHz.&&The specifications and a basic dimensional drawing for LCCN3025 male SMA connector can be found in this datasheet PDF.
          L-com’s SMA female connector for RG178 coax uses a crimp/solder attachment method. This SMA connector is one of the many RF coaxial connectors in L-com’s product line up and like all our products, they will ship the same day. Our SMA female connector operates up to a maximum frequency of 2 GHz.&&The specifications and a basic dimensional drawing for LCCN3022 female SMA connector can be found in this datasheet PDF.
          Would also make servicing the wtc easier.
