Disney nautilus 31"
    Heres a gooden:
      I resized it to 1024 and reposted. NO Difference. I changed the size to Icon, small, medium, large, full size. Makes NO difference at all.
        OK lets see what we can do today with the picture thing.
          Maybe now two?
            Nice big pictures of the Disney Nautilus. The subject of our build.
              More of the same
                A little bit of progress. To correct a small gap between the deck and the front of the wheelhouse I applied a little bit of Evercoat. Ill sand it down on a sanding block. Also to fill a few air bubbles at the stern.
                  Im working with Bob Martin on getting my grubby little hands on a Sub driver for this thing. Couple of weeks.
                    A few more pictures, if you please...................Maestro..............
                      Order placed for The Sub-Driver. STAND BY FOR ACTION!!!
                        There has been a delay in my acquisition of a Sub-Driver, but its in the works. Dave is all over it............................I think. At any rate, here is the prop that I ordered. Its 45mm, 7 blade. Looks very different from the normal Nautilus prop. The prop that comes with the hull looks accurate but its plastic, with almost no pitch. We needed more thrust than that prop could produce. Since the prop is 4mm drive, that pretty much dictates the size of the shaft and bearings, ...............................I think.
                        • Kim Sleep
                          • Nov 2013
                          • 329
                          #42
                          beautiful work
                            Ive received my Sub-driver and I am having Bob set me up with some custom made Sub-driver supports to make installation a breeze.
                              • 13950
                              #44
                              Sorry about the delay, Mark. Keep us informed of how it goes -- and don't be shy with the questions and complaints.
                                Dave and/or Bob Martin, Ive not seen anything on cutting vent holes in the bottom hull section. Do you think I need to get some holes in there or should I just skip it?
