Akula 1/144 Scratch built
  • bwi 971
    Scale wise I was not so happy......so I had another go at it.....0,2mm wire. Base just over 2mm. Looks more to scale now. Still needs some cleaning up.
    One ready two to go.
    And NO I will not try to squeeze in a LED (although it's tempting)
    Grtz,
    Bart Click image for larger version
Name:	Akula (306).jpg
Name:	Akula (305).jpg
Name:	Akula (304).jpg
Name:	Akula (302).jpg
Name:	Akula (301).jpg
    Originally posted by bwi 971
    The light on the pod...reached my limits on this one. All brass 0.5mm wire, glued together with CA. Base dia 3mm
    [ATTACH=CONFIG]n109719[/ATTACH]
    [ATTACH=CONFIG]n109720[/ATTACH]
    [ATTACH=CONFIG]n109721[/ATTACH]
    [ATTACH=CONFIG]n109722[/ATTACH]
    Now that's just crazy-small stuff! You're nuts!
    My effort at 1/16 scale:
  • bwi 971
Name:	Akula (290).jpg
Name:	Akula (298).jpg
Name:	Akula (297).jpg
Name:	Akula (292).jpg
    Much better, Bart. What I do is simply wipe some medium-thick CA over the offending engraved work then hit it with some accelerator, File the hardened goo flush to the surface and scribe into this new substrate. Much easier than trying to keep the scratch-awl tip from wandering around as it encounters different materials with their associated properties of hardness a brittleness. You can still see the previous work through the semi-transparent goo so that will guide you without need of re-marking the work.
  • bwi 971
    OK thks
    Reduced the point of the finishing tool from diameter 0.9mm to 0.5mm (0.035" to 0.019"). The difference is significant.
    As I had troubles to get the paint all the way down in the groves I decanted the paint so I can use it in the paintbrush, works great David.
    Grtz,
    Bart
Name:	Akula (278).jpg
Name:	Akula (279) in003.jpg
Name:	Akula (283) in002.jpg
Name:	Akula (281) in004.jpg
Name:	Akula (282) in005.jpg
    Sorry Sir, Yes Sir, Three bags full Sir. I'm going to the bunker where its safe and no knows my name......
    Originally posted by HardRock
    Great definition and constant depth, but I think that you are right. Just a bit too wide.
    Way to wide. What's wrong with you?!....
    (in the voice of A-number-1) WHAT DID I TEACH YOU?!!!!!!
  • bwi 971
    Gents,
    I have been doing some scribing practice on my master. As I have no idea how it supposed to look, can you please give some feedback. Lines to narrow, to wide, to deep,….
    I have the impression they are a tick to wide?
    Thks & Grtz,
    Bart
Name:	Akula (271).jpg
Name:	Akula (272).jpg
Name:	Akula (274).jpg
Name:	Akula (275).jpg
Name:	Akula (276).jpg
    I like your handle on the scribe in pic 11. Verry nice improvisation. What is the harpoon looking tool lower number 15? Dremel makes some fine engraving bits. I do a lot of metal work engraving, with the motor, but for plastics, just chuck up in the hand drill. Scribe your lines, then you can follow up with the various bits for width and depth. Like you say, practice practice, it takes some finesse. Once you can use a tattoo machine without too many mistakes, your ready for engraving. I learned how to tattoo on oranges. "if you got ink in the meat, you ain't ready" is what Goldie told me.Click image for larger version
ID:	98607Dave, if you have one of theseClick image for larger version
Name:	honey dipper.jpg
ID:	98608pull the stick off the ball, or drill an appropriate hole in the stick ir other end and toss the masking tape handle on the tool. You can just get the ball end, only, at the craft shop, If you dont want to take a perfectly good honey dipper apart. Especially if it belongs to YOUR Honey. Mrs E
ID:	98592 Click image for larger version
ID:	98593 Click image for larger version
ID:	98594 Click image for larger version
ID:	98595 Click image for larger version
ID:	98596 Click image for larger version
ID:	98597 Click image for larger version
ID:	98598 Click image for larger version
ID:	98599 Click image for larger version
ID:	98600 Click image for larger version
ID:	98601 Click image for larger version
ID:	98602 Click image for larger version
ID:	98603 Click image for larger version
ID:	98604 Click image for larger version
ID:	98605 Click image for larger version
    Pay attention to how the shank just above the tip is as narrow as can be without being so weak as to bend under the pressure of engraving.
  • bwi 971
    Scribing
    I have been doing some test for scribing. I used the needle of a pair of compasses, blunt the point (just a touch). It is ok…….here comes the but part.
Name:	Akula (269).jpg
ID:	98590 Click image for larger version
Name:	Akula (270).jpg
    The problem is that I have to go to deep to get the desired wideness of the grove. When I try to paint is the paint does not reach the bottom part of the grove. When I tried to scribe with a more blunt tool the grove looks like sh*t.
    So I wanted to post here a question how to do it but then I hit the search button of the forum typed “scribing” and the first hit was this.
    Scribing stencils, and a pointed needle (re-worked needle-file) is all you need. The trick is to start with the sharp point and to then make the finishing passes with a blunt point with a shank of constant diameter. Practice, practice, practice.
    It is all on the forum……So I have my starter tool just have to make my finish tool now.
    Grtz,
    Bart
    Carpe Diem Mate!
    Carpe Temporus Punctum-Edo Edi Essum Diem
    Well, after a couple seconds of dreamig about it, I ordered a small hobby lathe, When the Queen finds out, I'll blame it on Sir Bart. "The Black Knight" Mabe if I take a couple of her wooden spoons and turn spindells on the handles, I can get an approval of justification.
    Carpe Diem Mate!
    Go ahead David I will take the heat.....I which I had done the same ....just finished cleaning the house, next up is the laundry.....5 years to go (but it was worth it).
    I am thankful, that I manage to get out of laundry. I don't do it correctly, She says. I wash everything at once, her delicate things with my fishing shorts. I did it just one time and I have been forbidden to operate the machinery, for life. Cleaning the house however, is in my realm of job obligations. I make the biggest mess, so, you have to pay, to play.
