Overhauling the Walter V80
    What are you using for a vent valve?
      • 1661
      I used a standard FESTO valve, 12 V DC, this valve was allready present inside the boat, used it to seal off the ballasttank when the peristaltic pump was switched off.
      Normally you don't have to do this, but i like to over engineer things.
        Typically the vent valve is located at the top of the ballast tank. Here you have a pipe leading to the valve body inside the dry space. Do you see any potential problems with this set up, would the tank vent properly as with the valve directly atop the tank?
          • 1661
          Romel,
          My air outlet is also placed on top of the tank, did the same with my type VII, works like a charm for more than 20 years, the only issue you have is, yearly maintenance on the valve by taking it apart and cleaning it, if neglected you got yourself a jammed valve.
            • 1661
            The boat is almost ready for running in the open water, still have to tinker a bit to get her perfectly level underwater, made a vid with the V80 in the bath, enjoy
            To answer Romel's curiosity, divingtime about 30 seconds, and time to surface about 15 sec, a big improvement compared with the peristaltic pump, when she is all done i can conduct some testruns to see which results i get from the overhauling.
            The testprogram will be simple,
            - checking speed on the surface as well underwater, all done with maximum speed, no reduction on the throttle.
            - tuning in the ADF to get the best performance underwater.
            - running the standard 8 figure on the surface as well underwater.
            - re-checking the maximum drivetime, for now it was about 2,5 hours full speed.
              • 1661
              Wow, it has been 12 years since my last rebuild on the V80, i'm allready in the process building her up, a bit of a hurry to get her ready for next run in Germany, first i will show the cleaning out of the V80, pictures
              Front and rear hatch opened to get the stuff out.
              All hatchseals where shot, they will be replaced by new rubber.
              Middle hatch opened and took loose the peroscope stuff.
              Peeled out the cables at the front to get to the receiver batteries.
              Five Eneloop cells, giving me 6V 2500 MaH, more then enough to run her for a few hours.
              Rearpart stripped, had to take out the E motor to get to the main drive batteries.
              Main batteries removed, 12V 5000 MaH, giving me a drive time of about 2,5 hours.
              The state of the receiverpack, corroded due to moisture.
              Same story on the main batteries, they both held it for twelve years, so it was time to get me some new batteries.
              Hull completely cleared of all components, left the rudder and diveplane servo's in, no need to get them out.
              This pile got out, i want to avoid this mess of wires in the rebuild.
              More to come next days.
                • 1661
                I'm in bit of a hurry with rebuilding the V80, decided to make a vid of the current stage, i have less as a week to get it together and testing it for the next meeting in Holland, if there are requests about more details, feel free to ask.
