1/12 remote minehunting vehicle build
  • ffr2608
    • Oct 2009
    • 330
    Starting a new build thread on the Lockheed Martin remote mine hunting vehicle. Layed up a polyester hull, built the prop and shroud and started casting the dive planes. This is going to be a simple dynamic diver using a small WTC and a direct drive 540. The actual boat uses a diesel only drive with that huge snorkel feeding it. Perfect subject for the pool and pond. Control will be by a mixed x tail arrangement. Front starboard plane will be linked to the aft starboard plane turning opposite directions. Turns will be tight and diving will be very sensitive. Most likely an elevon mix with the dive dialed way back on the radio. Only one being built.
    D
    • 3419
    Impressive!
    Can't wait to see a video of her running.
      OMG! We got another Master Builder to rival the likes of Mamas Pitsilis and Dave Merriman and Joel and Pete P. and others. Im not included in this bunch, Im just a assembler type guy. Fantastic, looks machine made!
      • ffr2608
        • Oct 2009
        • 330
        Thanks Greenman....Most of it is machine made....Lathes, mills etc......
        D
        • HvyCGN9
          • Jan 2013
          • 187
          Very cool!!
          one of my TF72 clubmates has a 1/72 Arleigh Burke USS Pinckney DDG-91 with a non working RMS in the side hanger. (How cool would a 1/72 RMS be!!)
Name:	20121006 TF72 Wagga-Mick_0004a1.jpg
          Cheers Bruce
          • ffr2608
            • Oct 2009
            • 330
            That would be the size of a AA battery.. Nice model.
            D
              • 3419
              D
              You could tow it behind your destroyer like a paravane.
              • ffr2608
                • Oct 2009
                • 330
                Got the appendages cast up and the initial keel built. Plan is to hollow the keel out and fill it with lead to offset the large snorkel. I have a piece of streamlined aluminum on its way and will construct its base then. Size of this boat is really cool. A 3" tube will fit if I can get the linkages flush to the hull. If not, I will go with 2.75". I plan to turn them out of gray PVC.
                Started this project while I am waiting for parts to arrive on the Nacken. It is also a nice break from that monster.
                  • 3419
                  Whoa. You could actually fit a small diesel engine in there and make the snorkel functional.
                    • 13558
                    Any progress on the KILO?
                      • 3419
                      Yes. Bending those brass control rods to fit inside the stern cone is a pain in the ass!
                        • 2459
                        Crikey, I thought I chose some bugly subjects to model, that thing takes the cake!
                        • ffr2608
                          • Oct 2009
                          • 330
                          Andy, I don't take offense because I have never seen anything you've built.....
                            • 13558
                            Trust me, Andy's Certifiable nuts. You, Darrin, are Hog wild-dangerous-certifiable nuts.
                            There.
                            Clear?
                            You two should post your past and current works here. I'll determine who's king of the nut-jobs. How bout it, guys?
                            • ffr2608
                              • Oct 2009
                              • 330
                              I'm too busy building.......;)
