Now that I have all the required parts (except for the on/off switch....) I began the construction process back in December (using the other superb build threads as a reference source) taking my time only doing small bits of build at once. Normally I could build a plastic kit with this number of parts in short order, but as this one is going to be RC'd some patience is required.
I noted some of the builds have had issues with a gap along the hull separation, I decided to do the hull assembly in one hit....
Step1: Was a trip to the hardware store for a 110cm by 29cm Melamine board (which will become the base of the Shark's travel box later on),
Step2: Following Dave's instructions assembled the four hull sections upper an lower side by side on the board, but rather than leave them to cure on the board I put taped grease paper across the center hull area and attached upper hull (no glue!!) taping it and using rubber bands, this way they will cure mated exactly together...
Step3: left for 48hours due to work (to tired to do anything....better to leave it than stuff it up!) Removed tape and bands and got nice close fit all along hull.
here are some pics..
Bruce
Bruce
