1/96 Scale Shipyard Alpha
    I went looking thru my "Archives" for some pictures. Unfortunately, I dont have much on this type, showing the masts. Here is what I found.Click image for larger version
ID:	91434Click image for larger version
ID:	91435Click image for larger version
Name:	Flash drive 2 929.jpg
ID:	91436Click image for larger version
Name:	Flash drive 2 934.jpg
ID:	91437Click image for larger version
      Ok heres a few more. Remember, you got the long sail jobs and the short sail ones.Click image for larger version
ID:	91439Click image for larger version
ID:	91440Click image for larger version
ID:	91441Click image for larger version
        • 12334
        Great job on the paint and weathering work there, Hardrock. Good stuff, Mark. Thanks, guys. It' time for me to re-visit my old 1/72 ALFA.
          Thanks men. Appreciate the photos and the feed back. And thank you David for the bits and pieces - really helped a lot. "Short sail, long sail"? Are there two versions?
            Sorry, I was thinking of the Akula. Scratch that.
              I just read that the Alpha prop was made of titanium. Does that sound right?
                • 651
                The Hull is, so it could be
                  • 2759
                  That's one tough machining job.
                    • 12334
                    well... laudi-da-dah!
                    Oh, and the ALFA's looking good too.
                      Wondering if anyone (this means you Peter!) has any photographs of the Alpha's masts. Specifically the middle one with the radar dome on top.
                        Forgot to add a thanks to Mark for the last lot of Alpha mast photographs. It seems really hard to get a clear, close up view of the middle do-daddy (technical term). So far my best guess looks like this; but its a guess.
                        • Peter W
                          • May 2011
                          • 509
                          Blimey a hard one, not sure I can do much better than Mark but will post all I have....
                          Peter
                            Thanks Mate. The bloody thing looks different in EVERY photograph. Originally I thought that it had a square base with a radome on top but it appears to have two plate antennas - one on each side and a planar antenna at the front. Confusing.
                            • Peter W
                              • May 2011
                              • 509
                              you gotta wonder how far away it is from this Kilo mast....
                              Peter
                                Looks like the plate antennas are positioned on the long axis in this photo, and there are "balls" under the radome that I can't see on any of the Alpha photographs.
