Aluminaut Research Submarine 1/96th Scale
    • 3672
    #106
    Crazygary,
    I accept your suggestions, thank you sir!
    It will be a bit before I try that again, but because of you, the Aluminaut will live!
    Tom
    • crazygary
      • Sep 2012
      • 610
      #107
      Always good to hear that your creaton shall come to pass!!
      If ever I can help you out in any way, up to and including casting parts for you, please
      don't hesitate to ask!
      If the need should arise, I would be pleased to make uip a RTV mold of whatever you may need,
      and cast "away" ( No pun intended!) to the best of my current abilities!! ( Laeves alot to be desired, eh?? Hah!!)
      Crazygary
        • 3672
        #108
        Crazygary, I hope our paths cross.
        • crazygary
          • Sep 2012
          • 610
          #109
          Mornin', Tom!!
          I don't know what you're using to power your Aluminaut, but I'll be using Turnigy Nano-Tech 160 Mah, single cell LIPOs for my, eventual, 1" wtc. The connectors are crazy tiny, but I have managed to locate an adapter to charge them from any LIPO charger, as well as connectors to hook them up.
          TME ( Tejera Micro Engineering?) makes an "Ultra-Micro Battery Adapter" , as well as Ultra-Micro connectors, with either male or female ends. Found and ordered them from Horizon Hobby, as their website is where I found them! No affiliation with them, just damn glad to have located the elusive little buggers!!
          Hope this helps ya!!
          Have a good one
          Crazygary
            • 3672
            #110
            Crazygary, thank you for figuring the connector out, I have a couple of them, but wanted to make some connectors so I can make components removable easier. Ordered what I thought was the correct ones only to find they were 4x larger than I thought. I have since found them, but will not worry about installing them. So far, I can say that when I decide to tear this apart and redo it, I am going to make the component tray slide out and do as Ken did and create some circuit boards to consolidate wires and connections. Right now I want to complete this so I can work on my Skipjack. And get into something larger (feeling claustrophobic).
            The props were painted yesterday and will be mounting them in a short while. Maybe get a test in the tub going. There is another sub that was given to me recently that I will start a different thread on that got water tested last night.
              • 3672
              #111
              Painted the the props aluminum. I have seen photos of them painted white or gray, I chose aluminum because the Aluminaut was the first to use aluminum hull for a deep sea vehicle. Checked the reference photos and added the props.
Name:	Aluminaut research submarine 135.jpg
              Assembled the parts together and placed the sub in the water. The Aluminaut is nose heavy.
Name:	Aluminaut research submarine 136.jpg
Name:	Aluminaut research submarine 137.jpg
              But the piston ballast works very nicely.
Name:	Aluminaut research submarine 138.jpg
              I will need to reverse some of the servos and one motor does not turn as quickly as the other when the command was given. The people blender (being run by crazygary's ESC) works like a champ. I will need to limit the power to it. Just a small amount of power and it moves.
              Playing with it for several minutes, I got a tinge of panic, wondering if there was a leak somewhere. So time for a check.
              Opened up the sub and it was bone dry. The piston was dry and the end caps that the wires come into was dry.
              Trimming this is a little tricky because I cannot add foam. But I do have a keel that is filled with some weight. I can cut out or drill areas out to raise the bow.
              Assembled the sub again and cut out a strip of foam. Filling the ballast tank, the foam was held on to the hull with a rubber band. At first the ballast could not lower the sub, but as I pinched off pieces of the foam the hull was becoming more responsive. Then I slid the foam forward, I was able to get a level sail.
              So correct me if I am wrong, I have a chunk of foam 7/16" x 7/16" x 7/8" I need to convert this volume to weight and remove that amount of weight from the keel. Can someone help me figure that out?
                • 13668
                #112
                work out the volume of the foam, that's its displacement. Convert to ounces of water weight. Remove that weight of the lead, less the weight of the water displaced by the removed weight.
                  • 3672
                  #113
                  Sanity check -
                  LxWxH=Volume
                  0.875 x 0.4375 x 0.4375 = 0.1675 cu. inch
                  cu inch of water weighs 16.387grams
                  http://www.fourmilab.ch/hackdiet/www...1_4_2_0_7.html
                  16.37 x .1675 = 2.742 grams
                  I need to remove 2.74 grams of weight from the keel. Did I do good?
                    • 13668
                    #114
                    That'll work. Was the weight in the wet or the dry? If wet, you will reduce the amount of weight you're removing by the weight of the piece you are removing (I never calculate that, its very small -- just showing off). It's late, **** it .... I'm going to bed!
                    Love your work!
                      • 3672
                      #115
                      Thank you David for your kind words and help.
                      Removed the keel, benefit of using an RTV silicon.
                      It weighed 20 Grams. So if I took out 3.5 grams I can add weight if needed, but I will also be adding a light bar at some point.
Name:	Aluminaut research submarine 139.jpg
                      Hollowed out the front were the foam was and worked my way back.
Name:	Aluminaut research submarine 140.jpg
                      Cut open the sides were some scribing was for flood holes (the front is scooped out as an exit path too)
Name:	Aluminaut research submarine 141.jpg
                      Weighed the bar and hit 3.5 grams removed on the nose!
                      Feeling like I can conquer the world, I went ahead and began adjusting the servo directions and limiting the throw. Then...................
                        • 3672
                        #116
                        .....my world began to go up in smoke. Look carefully at the picture.
Name:	Aluminaut research submarine 142.jpg
                        Yes, billowy, curling, wisps of electrical meltdown AGAIN!!!!!
                        I went to bed and today after work (I had cooled down significantly) I went to investigate. This time it was the port motor. Here is what it looked like.
Name:	Aluminaut research submarine 143.jpg
                        Interesting, it is the same location on the board that died. So, until I can conclusively rule out these are bad ESC, DO NOT BUY THEM! I will contact the company I bought them from and see if there is any suggestions on their part.
Name:	Aluminaut research submarine 144.jpg
                        So, after a brief email from David, I am going to put this to rest for a bit and work on the Skipjack and a ballast system I have been itching to play with.
                        The other thing that has happened is I received a sub as a gift from a friend, Mike Dory. Will post more about that in a different WIP. I am taking David's suggestion and going to a movie (minus the drugs) and going to relax.
                        This thread is not over, just on hiatus.
                        Tom
                        • crazygary
                          • Sep 2012
                          • 610
                          #117
                          Appears to be a well deserved and needed break, Tom!
                          Yet another bad ESC???? Gees! I ordered, and have received, 2 more of them!!
                          Maybe not a good thing, eh?? Will be interesting to see what the vendor has to say
                          about them!
                          A little extra "excavating" room in the Skipjack will certainly
                          be a welcomed thing!!
                          The Aluminaut may well also benefit from a hiatus!!
                          As I'm "still" waiting for electrical connectors for the Virginias 1" wtc, I think I'm going
                          to concentrate on finishing my latest "target" this weekend!
                          My tug may actually get wet sometime Sunday?? (Film at eleven??)
                          Enjoy the hiatus and let me know where your Skipjack build can be found!!
                          crazygary
                            • 3672
                            #118
                            crazygary,
                            The vendor said
                            "ESC and the LiPo and the propellers and the motors they need to work
                            properly. You'll need to know the correct voltage about that. For this
                            special knowledge I do not know two much. As we have sold many of those,
                            we seldom get customers which have these issues. Many customers told that
                            the ESC fails because of the right ESC connect with wrong motors or LiPo
                            battery or right motors connect with wrong propellers, etc"
                            This is true, but there are no specifications on the web site. I did ask on a follow up if a battery and motor they sell is correct for the ESC, no response yet.
                            That being said, I have a friend who said the problem might be air flow, since one was sealed in liquid electricians tape and the other in shrink tape, that might be the case. These might need space around them.
                            I still think of solutions for it......
                            Right now I am filling my time with a couple of ideas I need to play with first before I get to the Skipjack.
                            Tom
                              • 3672
                              #119
                              Just a small update. Adam Carlson has created a very small ESC for me to test out in the Aluminaut.
Name:	Aluminaut research submarine 146.jpg
                              Here it is the one that self destructed (left) next to the new one (right)
Name:	Aluminaut research submarine 147.jpg
                              Time to dust off the parts and bring life back to this sub!
Name:	Aluminaut research submarine 148.jpg
                              • crazygary
                                • Sep 2012
                                • 610
                                #120
                                Good ta see ya back in the Aluminaut groove again, Bro'!!
                                Fingers crossed for ya with Adams ESC! I'm also on his " Gotta have one" list, so if you can make a good go of it, my 1" diameter WTC may actually come into its own!!
                                Kick tail and take names, Tom!! Best of luck to you and your sub! I will, indeed, be watching!! Would be way cool to see ya "git 'er done!!"
                                Crazygary
