Scaleships Akula II
    Originally posted by Peter W
    Right here is the antenna mast fitted too...
    [ATTACH=CONFIG]30772[/ATTACH]
    [ATTACH=CONFIG]30773[/ATTACH]
    Peter
    Hey Peter. I was just looking at the periscope in you photograph. Did you get a smaller (2 mm shaft) one in the kit as well as this one? The item that came with my kit was turned in the same way as yours but it was considerably thinner. Might just be the angle of the shot.
    • Peter W
      • May 2011
      • 511
      #167
      Scott,
      Thanks for the pics, No the periscope at the front is 3mm. Have to be fair I thought it was artist's licence on behalf of Scaleships as it isn't a match for any scope but is closest to that. I am not particularly happy with the way that scope turned out anyway so a remake is a good excuse to starting again......Sigh.
      Peter
        I've got a 2mm version if you'd like it.
        • Peter W
          • May 2011
          • 511
          #169
          Scott,
          Look I am not going say no but I really have trespassed on you generosity enough surely?
          Peter
            Its about $6.00 in postage. I think I can stand the pain.
            • Peter W
              • May 2011
              • 511
              #171
              If you are sure ......Your lot did just thrash our lot at the World cup so I suppose only seems fair !
              Peter
              • jenels4
                • Oct 2014
                • 44
                #172
                Is there like a model shop you can go to to get "detail" parts, such as those antennaes?
                • Peter W
                  • May 2011
                  • 511
                  #173
                  Most of the masts came with the kit. The long dark grey mast was made by Scott ( Hardrock) and is made using very, very thin telescopic brass tube. The light is also made by Scott but was made with the help of a lathe.
                  Example of a kit mast ..... Snoop Pair
Name:	Akula b 6.jpg
                  On the subject of masts .....I hate Rim Hat !
                  If you are after masts for your Alfa, then follow Scott's excellent thread on his Alfa. He is currently in the process of refining his selection, one point though is that the masts are a bit different between an Akula and an Alfa based on the decades between them, for example I haven't seen an Alfa with Pert spring and the Rim Hat mast is different between them. The Alfa used the MRP-23 Snoop Head/Bald Head mast instead of the Snoop Pair on the Akula.
                  Akula masts...
Name:	akula 9999999999999999.jpg
                  Alfa masts....
ID:	98038 Click image for larger version
                  Hope this helps.....Maybe ??
                  Peter
                    Peter
                    As an Officer (and a Gentleman) I could never stoop so low as to remind you how poorly you play Cricket!!
                    • Peter W
                      • May 2011
                      • 511
                      #175
                      You don't have to remind me I know......They just haven't a clue.
                      Peter
                        • 13609
                        #176
                        (you two should get a room and start picking out furniature)
                          Here's your periscope!
                          • Peter W
                            • May 2011
                            • 511
                            #178
                            Scott - Very, very nice ....thank you !
                            Mr M - All you need is lathe !
                            Peter
                              • 13609
                              #179
                              Peter
                              Remarkable work there. I'm taking notes.
                              • Peter W
                                • May 2011
                                • 511
                                #180
                                Right had a bit of a setback last week, as I am off work with an injured knee I have found out that I am not going to be paid by my firm for the time off. Even though it was a worked based injury. Sigh. I was saving a bit a month to get the Skipjack SD for the Akula so I am having to hold off. Gutted.
                                Anyway I have been off and have got some stuff done....
                                Have fitted the SOKS to the sail...
Name:	Akula b 99999999999996.jpg
ID:	98072 Click image for larger version
Name:	Akula b 99999999999995.jpg
                                I have also done a bit to the top of the sail, periscopes, handrail and other small details. So I decided on a self indulgent shot of most of the stuff fitted...
Name:	Akula b 99999999999998.jpg
                                This is just a, in current state, shot. Lots more to do. The Rim hat mast at the back was an attempt at a remake,the kit one came in many parts when it should have been 1 part. I am not the best in the world at soldering and I may yet find the gnawing, nagging feeling to re-remake it.
                                When this boat finally gets wet and when sailing it will not boast all of the scopes at the same time a few smaller ones will be fitted and the bigger rest will be for display only.
                                Peter
