As you can see the burr on the top one in the picture jumped a couple of times but it looks worse than it is. So far I am reasonably happy with the result although I am aware that the filler is going to be busy later on.
The other thing I tackled tonight was the propshaft sleeve position in the stern, with this kit you get a 5mm stainless steel rod about 9" long and a 2" sleeve for it to go through, a bit shorter than I am used to pro-rata to the length of shaft but there you go. I took my time over this and am happy with the positioning to the point that I tacked it into place with CA.
However here comes the biggest problem with this kit or rather my hull. This is where advice would be very much appreciated. I have a massive alignment problem longtitudinally. I work in the construction trade and have a pretty good eye for level and true but I can not see where the problem is.
They say a picture paints a thousand words well 996 of them are rude !Swearing Smiley
As far as I can tell the top half should pretty much touch the bottom half, there will be a gap of between 1/16th and an 1/8th but nothing compared to the leviathan I have here. I am currently thinking that I may have to sand the belly out of the upper hull but any suggestions etc. would be wonderful.
Peter
Please help !
