Building the little Kilo submarine
    • 3699
    #31
    Manfred,
    what model kit is this? Is this trumpeter’s 1/144 scale?
      • 1597
      #32
      Tom, yeah it's the trumpeters kit, had it laying around in the stash, must be at least a decade or so.
      The intension is a kind of recruiting boat, to infect more people to join the tribe.
      Working on the floodholes and some other stuff.
        • 3608
        #33
        Manfred, regarding your DIY endcaps, what's the thickness of the plexiglass discs and what cohesive did you use?
          • 1597
          #34
          Romel,
          Thickness is 5 mm, used 2K epoxyglue, during curing placed them in the vice, released them after 24 hrs
            • 3699
            #35
            I am not a big Kilo fan, but your idea as an introduction for unsuspecting and vulnerable children is brilliant! Much like how David does it or how I got hooked back into this hobby.
              • 3608
              #36
              That DIY WTC of yours will likely fit in the Trumpeter 1/144 Japanese Soryu.
              Screen grab from a Thai modeler's FB post.
                • 3608
                #37
                Did you encounter the same thinned out or under cast resin dive planes? Click image for larger version
                  • 1597
                  #38
                  The Kilo is a bit small for my taste, but ideal to hook up interested people, especially during poolruns, due to the size it's a nice boat to keep your skills sharp, i' ve got me the XXI for more victims.
                    • 1597
                    #39
                    No problems with thin casted resin parts, those things are a bit tiny and have to be handled with care.
                      • 1597
                      #40
                      Floodholes are done, made the provision for steering the front dive-planes and a dryfitt of the hull parts,
                      Click image for larger version  Name:	20251124_101506.jpg Views:	0 Size:	47.5 KB ID:	195587
                      By using a metal rule as a guide, i made the floodholes with the Dremel
                      Click image for larger version  Name:	20251124_103048.jpg Views:	0 Size:	46.9 KB ID:	195588
                      Cleaned up the floodholes with the X-acto knive and some sandpaper.
                      Click image for larger version  Name:	20251124_193626.jpg Views:	0 Size:	58.8 KB ID:	195589
                      Made this contraption for steering the front dive-planes, it will be connected magneticly to the steeringrod on the SD.
                      Click image for larger version  Name:	20251209_215759.jpg Views:	0 Size:	42.4 KB ID:	195590
                      Made a proper stand for the boat, compared to the stand delivered with the model it's more beefy.
                        • 1597
                        #41
                        Made some studs near the middle part of the hull to get it less flexing at that point.
                        A dryfitt of both hull parts, for now it seems to be looking good, next step will be, replacing the plastick railing by 1 mm copper, those plastick rails is asking for trouble, even by looking at them they will break.
                          • 3608
                          #42
                          Will you be fixing the sail to the deck or make it removable?
                            • 1597
                            #43
                            A permanent fix to the upperdeck is not what ik have in mind, i like to have things removable for maintenance or transport.
