1/72 ALFA build
  • Joe oliver
    • Oct 2024
    • 8
    1/72 ALFA build
    Is there a precise sequence and instruction for installing the rudder and stern planes and control linkage yokes. There numerous photos but out of sequence and with little or no description.
    Joe
    • 3473
    Try David Merriman's 1/72 Alfa Cabal Reports
    • Ken_NJ
      • Sep 2014
      • 989
      Joe, David's Cabal reports gives quite a bit of detail on the boat. Looks like pages 20 and 32 should answer some of your questions. For further answers perhaps try to post some pictures of the parts using the email I sent you on how to post pics.
        • 13634
        Joe
        YOU PEOPLE!!!!!
        Joe: anyone crazy enouogh to get a surface-piercing hydrofoil to work can work out a stupid submarine models assemby chronology of assembly and associated fabrication methodology.
        DON'T MAKE ME COME OVER THERE, pal!
        First, assemble the hull and as you do so, work out the Z-break between upper and lower hull, and mount all the appendages. Second, get some idiot to provide you a proper SD for the thing (I know just such an idiot). Three, with the SD in hand work out the control surface linkages and SD foundations. Four, trim the boat. Five, sing my praises.
        Look over this video, Joe. The pertenent sections start at 7:15 and 39:00 https://youtu.be/H4q1NO_IQGk
        The Horrible
