Jake's SSN-591
  • Davjacva
    • Nov 2022
    • 408
    Finishing prep-painting of the hull. Used a fiberglass brush along with McQuire's Fine Cut Cleaner which softens the applied paint in order to make a thick streaking effect. This was another of Dave's techniques that really worked out very well. Next a clear coat will be applied to save this stage of the work for the follow-on weathering to be applied.
    • Davjacva
      • Nov 2022
      • 408
      Here the paint-work is being completed and unmasked. I also provided a photo of Dave's automotive clear coat kit. You can go gloss or add a flattening agent. Awesome stuff. Going to get some. Click image for larger version
ID:	181721 Click image for larger version
ID:	181722 Click image for larger version
ID:	181723 Click image for larger version
ID:	181724 Click image for larger version
ID:	181725 Click image for larger version
ID:	181726 Click image for larger version
ID:	181727 Click image for larger version
ID:	181728 Click image for larger version
ID:	181729 Click image for larger version
ID:	181730 Click image for larger version
ID:	181731 Click image for larger version
ID:	181732 Click image for larger version
ID:	181733 Dave did some touch up work a few days later, then it was time to throw it in the water for surface/ submerged trimming. Now...the only thing coming out of this model prior to painting was some foam, and we went with a battery that wasn't even half the weight. So you figure you're going to be on the light side of things...we kept adding foam, more, more. Finally, Dave said something's up, we're getting water some where we don't want. Sub kept going to whatever version of Davy Jone's Locker is in that dunk tub. Sub came out, opened it up and it was dry as a bone. Perplexing, so we glued some in and tried it again and pretty much got it dialed in.
      • Davjacva
        • Nov 2022
        • 408
        After four months of hull re-work and re-painting, finally got to dunk the sub in the lake. Had very few surprises, and just a few tweaks. The fairwaters weren't behaving with any kind of useful range, but Dave got them pretty ironed out after a couple times in the water. The trim was overall SAT, but heavy forward, light aft. I'll shift some foam this week and that'll take care of that. As you probably noticed, the paint job is from a commissioning one where the hull red is at the waterline, vice an operational one where is down at the centerline. Sometimes running the boat early on, I'd lose it, but then the red would stand out in the green water magnificently. Now I ran a 7.2vdc NIMH battery in it for about 2 hours of run time. When I took the battery out and check it on the meter to see how much juice was left, it still at 7.6vdc. Click image for larger version
ID:	181735 Click image for larger version
ID:	181736 Click image for larger version
ID:	181737 Click image for larger version
ID:	181738 Click image for larger version
ID:	181739 Click image for larger version
ID:	181740 Click image for larger version
ID:	181741 Click image for larger version
ID:	181742 Click image for larger version
ID:	181743 Click image for larger version
          Very nice job.
            • 3737
            Congratulations Captain! Nice looking and a sweet running sub to boot. I always get nervous when a sub is trimmed one moment and then the next time it is not. I start going through a mental checklist. Is it leaking?, Is there air trapped?, Is the battery shifted?, Did I lose a weight/float? Because, for me, I fix something and then the next time I run the sub, I have to undo what I did. Gotta love this hobby. It keeps you on your toes!
            • mike27283
              • Aug 2020
              • 47
              Jake (Chief) - when are you going to be over at Dave’s? Would love to stop by for a zone inspection of the Merriman spaces!
                • 2041
                Loving it, Jake! Gorgeous little boat!
                  • 13950
                  Oh, Great! Another white-glove house prostrate exam by the good Captain. I just have time to scrub the ****ters and put up the bunting...
                  Jake will be over late morning, sir. Come on over.
                  • wlambing
                    • Nov 2020
                    • 394
                    Does Mike use that thicker A-cable grease to ease the entry of the white glove, or does he just go with a whopping good dollop of Prussian Blue so in the end everything looks way more festive????
                      • 13950
                      Neither. Course lapping compound.
                      • wlambing
                        • Nov 2020
                        • 394
                        Nice! I bet that provides a very nice finish! Is Mike coming north, too, to perhaps see if he can stick his Type VII under the aerator piping again? All of the work being done is making it look very good!
                        • Davjacva
                          • Nov 2022
                          • 408
                          Tom, so many interfaces to have fun with and screw up right? ha ha It's the on-going science project. It's amazing at how something can get out of whack just sitting there.
                          • Davjacva
                            • Nov 2022
                            • 408
                            Mike, he fails constantly, but...he doesn't care :)
                              • 13950
                              Just bring the coffee as directed, leave it in front of the door, knock three times, then get the **** outa my yard!
                              • mike27283
                                • Aug 2020
                                • 47
                                #30
                                Apologies for missing the jocularity on the thread - yeah…the health and comfort inspections are always met with a certain laissez-faire attitude by Dave…but the lube (and bunting) helps. Yes - that damn pipe!! Luckily Dave was the hero and pulled it out for me. Have the radio fixed now as well as a more robust bowplane connection to prevent PIO. Attached a photo of the man in action - classic!!
