    Yeah. And note the need to make the attachment of the bow and stern plane 'guards' much more robust than what the kit calls for. Those will snap off if you don't reenforce the bond between guards and hull.
    Was wondering about that. Good call.
    Thanks, will do!
    Thank you Sir!, and appreciate the aditional operations
    David where should the cylinder be placed? Mine is 2.5”, 23” long including a 7” ballast tank.
    Longitudinally, place the center of the ballast tank at the center (half-way point) of the hull.
    You've successfully hurtled the hardest part of this project. Well done, sir.
    Port Side Seam
    This is a better pic, last pic was distorted Click image for larger version
    Thanks David
    Ok, seams and hull clips complete Click image for larger version
    Looking great.
    Unrelated, Last Pool Run Skipjack 2023
    Looks great. My diamond cutting wheels have been delivered.
    Thrust Bearing, final will be thicker Click image for larger version
ID:	175096 Click image for larger version
