S.M. U-1 (a new RC project)
    • 1393
    Those who know me and my journey through the aeons of this board will remember the first build I showed here....a topic with almost the same name, S.M. U1 the first submarine of the German Imperial Navy (seems like the original thread is gone).
    I built this boat semi scale and quite large, about 1,8 meters long. Still have it, still like it, but as it was my first RC scratch build it has shortcomings that annoyed me over the years, nevertheless. So about a year ago I decided to re-draw the CAD model of the hull and I talked a bit with Mr. Merriman about a smaller scale boat and a WTC that would fit. We decided that 1:48 and a 2" Cylinder might be a good idea, as it makes the boat comfortable 88 cm long.
    Lately I was a bit bored, and my 3D-printer had nothing to print, so I checked, If I can chop up the hull in reasonably large segments, that are still printable on my Saturn. Turned out that 5 x 16cm long segments are ideal. I decided that I want to make a master for a GRP hull. So I cut up the CAD model and decided that the alignment and stability of the segments will be provided by a 25 mm x 25 mm stainless steel tube. I designed the corresponding square tunnel into the segments, made a test print, adjusted the CAD model in size and gave it a go.
    This it the result. I'm quite pleased how everything turned out. I'll have to make minor adjustments on the sides, where I had the support structure, but besides that ... perfect. When I find the time I'll make the adjustments, glue the segments onto the stainless tube and start filling the little gaps between them. Should be straightforward.
    • 1121
    Very nice! What are the improvements over your first model?
      • 1393
      The compete hull is a new designe and much more accurate than the first version. The bow is new and has the right cross sections, the stern has the right cross sections, the deck is curved the radii on the transition from deck structure to lower hull are right. The general look ist the same, but it's a completely new hull.
      And no idea about the wtc yet. The boat can fit 2" tube. That's all what I care about right now. Making a good master in a technique that I haven't employed before is the main thing right now.
        • 1393
        There is an awesome cutaway model in the Deutsche Museum where the U-1 is located today....
        Dies steht im deutschen Museum. Hallo Alfred, das ist ja wirklich sehr beengt! Vielen Dank für die Bilder
        Cheers Andreas
        • Davidh
          • 719
          Andreas,
          I will be looking forward to seeing how this goes. Loved your U-1. It helped inspire my U -23 build, a boat that is a lot of fun the drive.
          David H.
            • 1393
            Yeah, I like your U-24. Is it a good runner? I like these early Imperial German boats, but the arrangement of the control surfaces (all on the bow side of the propellers, not after them, in the prop stream) usually makes them a bit hard to turn and pitch control is tough.
              • 1121
              Its probably the best kit David produced so far. Shame shame mine is still resting on the attic, taped together and awaiting construction
              • Davidh
                • 719
                Yes U -23 runs nicely. I thought it would porpoise with the boat hull shape, but it doesn’t. It looks awesome on the water.
                Joerg, Thankyou for the compliment. I’m glad it isn’t in your Garage!
                  • 1121
                  What garage?!
                  wintertime sees attic-action!
                    • 1393
                    In a first step I glued all the segments onto the 25 mm x 25 mm steel tube suing epoxy resin. The seams between the segments were filled with epoxy resin that was transformed into a putty using micro balloons. Resin mixed with micro balloons can fill large gaps without cracking, is easy to sand, and gives a good foundation for the polyester putty that will be applied next.
                      • 1393
                      A little progress....master building galore: I filled the seams between the 3D-printed segments using polyester putty and now it's grinding, grinding, grinding....
                        • 1393
                        Wet sanding the seam....I really hate it. But I make progress.
                          • 1393
                          I have filled and sanded all the seams and obvious geometric flaws. Looks not like much, given the hours of sanding that went into the master so far. But it feels very different by touch and one can see form the putty areas, that there were quite a few uneven regions that are now straight. Next I'll glue some threaded insets into the keel to get attachment points for painting and mounting and the we are ready for the first round of 2K filler....
ID:	176355 Click image for larger version
ID:	176356 Click image for larger version
                            • 1393
                            Lots of progress...well, invisible one, as filling and grinding doesn't change the shape of the boat much, bit it will be visible, when the filler is applied. And that's what 's going to happen next. To be able to apply the filler/primer, I have to suspend the boat somehow. as there is no obvious attachment pint, I had to create it myself. So I glued two M4 threaded insets into the keel and made a suspension frame with a counter weight. Now the boat hangs straight and freely accessible under the ceiling of the work shop. Next I will degrease it once more with "Silikonentferner" (I guess something like the soft solvent David uses). And then it's going to be 2K epoxy filler/primer.
                              • 1393
                              Time for some 2K epoxy filler....nasty but good. Went well. When the filler is cured it's 600 grid wet sanding and then'we'll see. I guess I'll need some more bondo here and there, but as the master determines how good the grp hulls will be, it's worth the effort.
