S.M. U-1 (a new RC project)
    • 1393
    #76
    On Sunday I laminated the first halve of the conning tower mold and filled the box with a mixture of resin and quartz sand. Literally it makes for a rock solid mold. Today I removed the box and the parting plane. Worked out quite smoothly. Then I set up the box for the second halve of the mold. Quick job with such a small mold.
      • 1393
      #77
      While making molds, I have to take care of the additional parts that will be needed. On example are the sub deck structures that house the air intake masts. In my first U1 these were 3D-printed and I'm going for 3D-printed parts again, but with a big difference. The first ones were thick-walled monsters that displaced allot of water and that's above surface. So they contributed to the problem of having large enough ballast tanks. The new ones will be cage like structures with much less volume and only rigid walls, where they are needed, e.g. where the bearings for the mast axis will be set in.
        • 1393
        #78
        I finished the molds for the conning tower and opened them. Went reasonably well, but again, I had little section of surface primer stuck in the mold, that had to be removed with brute force, resulting with partially rough surfaces. Not really happy about it, but I guess the mold will be able to produce good parts. We'll see. On the bright side: The PE sheets have arrived.
          • 1393
          #79
          laminated the second conning tower today. First try wasn't perfect with voids here and there. So it's a second one, this time with thinner, more flexible glass and some more thickened resin in the corners. Worked well, we'll see the result in 36 hours...meanwhile: I printed control planes, hatches, and some accessories....
          Click image for larger version  Name:	U1-136.jpg Views:	12 Size:	45.6 KB ID:	182962
            • 14006
            #80
            That always evident German slavish pursuit of perfection to the most basic of items.
              • 1393
              #81
              Actually I hought a while abut the control planes. The original ones were very thin, and to properly reporduce those in that scale....3D-printing is the ideal approach.
                • 1393
                #82
                Working on the acrylic covers to get a nice edge to the hull parts. So far so good....
                Meanwhile: I pulled the second part out of the coning tower mold. Worked well. Still a bit on the heavy and thick side of things, but besides that, quite O.K.. I'll make a few more. One will go onto the RC version, one on disply model, and one for someone else....
                  • 1393
                  #83
                  While I prepped the mold for the second conning tower, I printed the housings for the air intake masks. Turned out quite good.....optimized for little water displacement.
                  Then I made the second conning tower. Got me new surface resin and a better color for the resin. So this went better than for the first one. After brushing in the surface resin, I poweder the resin with cotton flakes to provide a good coupling surface for the GRP. And the second tower is quite good. The first one was O.K., the second one is good. Less bulky, a bit lighter, no voids. So the next ones will be made to match this one.
                  ​ Click image for larger version
                    • 1393
                    #84
                    I have laminated the first deck section of the U1. Went quite well, despite the tight radius here and there. I used 3 layers of 80g/m^2 glass, the middle layer diagonally to give the deck some more resistance against twisting. Looks good and the conning tower fits perfectly. Going through the effort of making the three piece mold for the conning tower was quite worth it.
                      Will this be a one-off or will you be making more?
                        • 1393
                        #86
                        I've made molds and a few sheets of PE....so probably more than one. But I'm not a good producer for others. The little time I have for my hobby is mostly reserved for myself. Producing a kit is probably 20 hours of work.
                          • 1393
                          #87
                          Working on the fleet....
                            • 1393
                            #88
                            Got the molds for the lower hull going and Friday I laminated the second piece. Took it out today and turned ot quite good...one more to go.
                              • 1393
                              #89
                              Got a little package with a beautiful WTC and some excellen detail parts made of resin and white metal by the grandmaster David himself. I'm very happy. So after my Type II project I'll have something new to do....
                                • 1393
                                #90
                                So it’s time to continue my U1 project. I‘ll make two versions, one for display and a rc one. This is going to be the display one. I started with the upper hull. I opened the deck for the ventilation mast boxes, glued the 3D-printed boxes in from below and the filed the deckopenings to match the boxes. Filling and sanding after that. The limber holes are long horizontal cuts. To support the superstructure after cutting, I glued 12 bulkheads into it. Should be plenty….
