1/144 Nautilus Typhoon PETG
  • FindingNemo
    • May 2022
    • 51
    Intro
    I'm way overdue posting about my first build, especially since I started planning this in the 1970's, but I wanted to get some mileage under my belt first. So I finally present the ROTC - Ridiculously Overcomplicated Typhoon Construction.
    My Background
    I've wanted to build an RC sub ever since I saw a PVC and fibreglass Charlie class in Model Boats magazine. My grandfather was a radio technician in WW2 and built his own RC system in the 50's. My father started building RC boats shortly after, and I grew up in his workshop, but never got around to building a boat before now. I looked at the Engel Typhoon a number of times, but the cost was too high. However the 3D files from Bob, combined with limited time left for my father to see me finally build something meant it was finally time to start. But after all this time and planning, I wasn't going to rush.
    The smart thing would have been to follow Bob's advice and start simple. But my plan was to do it once and do it right (even if doing it once meant doing each step over and over..)
    I spent three of my six high school years at a technical school covering welding, casting aluminium, sheet metal work, lathes, milling, drafting, electronics etc. As my father was an architect I got early access to CAD software. Eventually I studied computer engineering, and many years later I am now head of engineering at a production plant that makes a wide range of products. I've had a range of hobbies from programming games to building houses and building/racing cars.
    What I am loving about this build is it's exercising a vast range of my technical skills, and building new skills. I love hitting a problem and then trialling solutions. I'm not counting the hours nor revisions- that's for the office.
    The plan
    The 3D Typhoon printed in PETG, with a Nautilus V2 cylinder, with the addition of bow plane hatches, twin sets of scopes, bow thrusters, and sequential opening missile hatches. Fortunately Bob talked me out of the thrusters early, because although I had assumed the Typhoon would have room to spare, once the cylinder went in there was no space for a thruster.
    The remaining mods are a big threat to the centre of gravity, but the fall back plan is to have a static display top hull with the bells and whistles, and a simpler version in water. It's too early to tell if I need to fall back.
    Hull modifications
    I found one of the lower hull files had the side rails detached. I imported this into Tinkercad and added internal blocks. While this was a quick fix, Tinkercad loses resolution, so this piece needed more filling. A fully licensed version of Fusion would be better as it has mesh to solid conversion. When you first install Fusion now you get full functionality for a while, but my aging PC couldn't handle the calculations for so many polygons on a curved hull.
    A crack appeared between two lower hull sections, so I fibreglass reinforced the lower hull. The thin section between missile hatches on the top hull is reinforced with brass.
    My inexperience shone through when my prop shafts finally went in and were slightly misaligned compared to what I had intended. I had created a jig when drilling for the bushings, but this wasn't good enough. I've carefully aligned the shafts now to avoid binding, using a custom 3D printed adjustable mount. I would love to know how others ensure shaft alignment.
    While working on th​e stern, I took my eyes off the bow end and found I had left insufficient room for a simple linkage to the bow planes. I also had to account for my missile hatch and bow hatch mechanisms. Once again the 3D printer came to the rescue and I designed a set of brackets (imagine a Z mating up to an inverted T) to set back and hold the magnetic links.
    Missile hatches
    A glutton for punishment, I wanted a mechanism that opened the hatches in a staggered fashion. I also wanted the tops of the missiles visible, despite limited room above the cylinder below. I went through multiple designs and trial and error, but have settled on a sliding cam, with worm drive, waterproof geared motor, and microswitches for each bank of hatches. Some parts are still on a slow boat from China, but here's hoping this works (and the waterproofing holds).
    Bow hatches
    I could write pages on the development of this mechanism but will try and be brief. I needed an adjustable, robust mechanism, and went through countless designs. It has a 3D printed rack and pinion to deploy the planes. The hatches only just clear the pitching mechanism and retracted planes. The system assembles like a 3D puzzle. Adjusting in situ was a nightmare, until I printed a translucent jig. Hopefully I can then transfer the adjusted mechanism directly to the top hull. A waterproof servo mounted low in the nose operates the hatches.
    Twin scope mechanism
    Another waterproof geared motor, worm drive and microswitches lifts the attack scopes when driven forward, and the Nav scopes going backwards (scopes down is between these two positions). A clutching mechanism engages/releases a pin on each set of scopes scissor lift. A 3D printed spring is hidden inside. The mechanism is mounted to a removable bracket.
    Sail
    The other significant mod that happened along the way was the change to the top of the sail design. I realised the files had a flat top, and I wanted something closer to the real design. LEDs for the Nav, front and warning light will operate in different modes, depending on the scope status.
    Drydock
    Rather than the typical wooden cradle I decided to make a combined display, build and carry case. The top part attaches to the cradle and provides a sub shield. I am worried about heat (I'm in Australia) and the PETG. Various printed parts have Jones & Son & Son imprinted on them, as a nod to my father and grandfather.
    Electronics
    A 26Mhz 10 channel Futaba system controls the cylinder. An Arduino replaces the originally planned bow plane interlock, in order to add an interlock for the bow plane hatch. Another Arduino controls the scopes and missile hatches.
    What's next
    The hull is ready for filling and painting. The bow hatch mechanism is ready to install and then to finish the linkages. A new V3 end cap is waiting for servos to be moved from the prior design (there wasn't enough space for the wiring on that one). Ceramic bearings are on their way before I finish the missile hatch mechanism.
    The actual scopes need building, aligning and attaching to the scissor lifts. Then trimming in the pool, before actually looking for a place I can run her, as our local RC club runs on a brown, weedy lake!
    Future plans might include a CR-30 printer. I would love to print a hull piece in a single print! Perhaps a scratch built Tintin shark submarine for the next build.
    Thanks and regards,
    Colin Denman-Jones.​
    A real plate-full for a first boat.
      Colin,
      an awesome project you got going there. WIshing you the best of luck.
      Would it be possible to get a scan copy of that vintage magazine article you posted. Thanks
      Rb
      • vital.spark
        • May 2010
        • 312
        Colin, What you have accomplished is what most of us could only dream about! Good on ya Mate!
          • 3769
          Colin,
          You have stunned me with what you have accomplished. Well done.
          • hywel
            • Aug 2022
            • 65
            Congratulations on your progress!!! Awesome stuff, Colin.
            • Scott T
              • May 2009
              • 414
              Like the coffee table size carry frame.
              Everything else is Mucho awesome.
              • FindingNemo
                • May 2022
                • 51
                Way overdue update in several parts:
                I finished the hull, with the pain scheme reflecting Arkangel in her later years. I created custom decals, as best as ai could figure out from the blurry photos and videos available. This included scaling the depth lines to account for the curvature of the hull. I used a laser line to mark the waterline.
ID:	183064 Click image for larger version
ID:	183065 Click image for larger version
ID:	183066 Click image for larger version
ID:	183067 Click image for larger version
                • FindingNemo
                  • May 2022
                  • 51
                  I completed the twin periscope mechanism, plus lighting system, and twin staggered missile door mechanism. These are controlled by an Arduino on a custom circuit board, driving a bought motor driver (encased in resin).
                  Click image for larger version  Name:	20231201_223728.jpg Views:	2 Size:	102.2 KB ID:	183070 Click image for larger version  Name:	20231214_214639.jpg Views:	2 Size:	61.6 KB ID:	183071 Click image for larger version  Name:	20231210_094654.jpg Views:	2 Size:	65.9 KB ID:	183072 Click image for larger version  Name:	20231217_091834.jpg Views:	2 Size:	65.3 KB ID:	183073 Click image for larger version  Name:	20230826_103258.jpg Views:	2 Size:	71.6 KB ID:	183074 Click image for larger version  Name:	20231201_223630.jpg Views:	2 Size:	67.5 KB ID:	183075 Click image for larger version
ID:	183094 Click image for larger version  Name:	20231227_184810.jpg Views:	2 Size:	80.4 KB ID:	183078 Click image for larger version  Name:	20241009_215349.jpg Views:	0 Size:	72.2 KB ID:	183092 Click image for larger version  Name:	20241009_215252.jpg Views:	0 Size:	47.6 KB ID:	183093 Click image for larger version  Name:	20231218_215158.jpg Views:	2 Size:	71.3 KB ID:	183077
                  • FindingNemo
                    • May 2022
                    • 51
                    I completed the bow plane doors, retracting planes and pitch mechanism, with another Arduino and customer circuit board controlling the two-stage lock outs.
ID:	183086 Click image for larger version
ID:	183085 Click image for larger version
                    • FindingNemo
                      • May 2022
                      • 51
                      Now I was aware from the beginning the risk of adding mass above the centre of gravity, and above the waterline. But never did the calculations on volume. Because the mass of course impacts the stability, but its the volume above the waterline that dictates the size of the buoyancy tank. All that extra mass needed extra foam and ballast to improve the stability, but sea trials quickly showed I didn't have a big enough buoyancy tank.
                      To make matters worse, the missile door mechanism jammed, but I didn't have the opportunity to remove it, as I needed to keep the mass in place for the trimming. Calculations showed I needed to massively increase the tank. I had to design a tank that would fit around the bulkheads.
                      At this point I knew I was getting into trouble. It's also when winter (southern hemisphere) kicked in, and became too cold to continue in the pool.
                      Two years constant effort had taken its toll, and I was in need of a rest. In that time my father had passed away. He didn't get to see the sub in the water, but he did get to see it in one piece, and he got to see the various components I had designed. I had also learned quite a bit about myself. The part I most enjoyed was the problem solving. Designing different mechanisms and iterating them until they were reliable and efficient. I don't really enjoy the painting and detailing. Also I'm not really into the social side. I have visited my father's model boat club since he passed, but mostly out of respect, and to show them the sub. I also leaned what I had been told from the beginning by the experts on this forum- sub's are incredibly complex, and pools are very hostile environments.
                      So now the sub is on display on the shelf, next to my father's boats. I have detoxed with a couple of simple projects over winter. I don't know if I shall continue the challenge of completing the tanks and getting her fully functional- it's not that far off. Perhaps after Christmas..
                      Click image for larger version  Name:	20240304_175703.jpg Views:	0 Size:	66.4 KB ID:	183089 Click image for larger version
                      Click image for larger version  Name:	20241009_214236.jpg Views:	0 Size:	62.3 KB ID:	183088 Click image for larger version  Name:	20241009_214230.jpg Views:	0 Size:	69.3 KB ID:	183090
                        Colin,
                        Masterful build on your Typhoon! Also, very nice photos of your other boats! Sorry about the passing of your father, but I am sure he would (and is) proud of what you have done...
                        "Firemen can stand the heat."
