Nautilus Drydocks Typhoon
  • hywel
    • Aug 2022
    • 65
    Originally posted by RCSubGuy
    I have the files done up for Russian boat periscopes and masts in 1:144. Here is the link to the files:
    These periscopes and masts are rendered in 1:144 scale, but can be scaled to anything you have need for. Nested on a build platform for easy printing, these are NOT recommended for FDM (filament) printers due to their detail and fragility. These are designed to mount to a piece of aluminum tubing and the detail parts represent the tops of the masts and periscopes.
ID:	163824Click image for larger version
ID:	163825Click image for larger version
    Those are amazingly detailed, Bob. Once my current print finishes I'll give them a bash! Cheers!
    • hywel
      • Aug 2022
      • 65
ID:	163849Click image for larger version
ID:	163850Click image for larger version
ID:	163851Click image for larger version
      Latest print pics...going out of order a bit, next up is the front bow.
        • 1570
        What kind of material do you use and what print setting? The surface looks really smooth.
        • hywel
          • Aug 2022
          • 65
          I use Deft resin in a Peopoly Phenom printer - just running with the defaults at the moment and seems to be quite good.
          • FindingNemo
            • May 2022
            • 51
            Oh that's awesome. It's been a struggle to get good images. I searched for Snoop Pair and all I got was a Rapper. :)
            • FindingNemo
              • May 2022
              • 51
              RCSubGuy Bob can you advise if you had to take any poetic licence with any of the scopes based on lack of information, or did you find good sources?
              The Radian especially looks fantastic.
              I will see what I can find on the Salyut radio sextant.
              Thanks,
              Colin.
              • Sinksalot
                • Mar 2020
                • 362
                Some one once sent me these pictures. But as I really don't build Russian subs, not much use to me. I don't know how real they are.
                • hywel
                  • Aug 2022
                  • 65
                  Sinksalot those are some amazing pictures, thank you SO much!
                  • SubICman
                    • Jun 2022
                    • 87
                    Radar antenna post “Radian” MRKP 58-SNOOP PAIR
                    • FindingNemo
                      • May 2022
                      • 51
                      The Typhoon has the twin dish Snoop pair, as seen in the photo above, not the single as shown in the drawing. The drawing also doesn't show the Rim Hat, and had at least the satellite antenna in the wrong position.
                      I see I mixed up two radio sextant designs I was halfway through creating the Saiga style..
                      • FindingNemo
                        • May 2022
                        • 51
ID:	163908Click image for larger version
ID:	163909Click image for larger version
Name:	Light array.JPG
ID:	163910Click image for larger version
Name:	Scopes detail 2.JPG
ID:	163911Click image for larger version
ID:	163912Click image for larger version
Name:	Scope detail.JPG
ID:	163913Click image for larger version
ID:	163914Click image for larger version
Name:	yellow light.JPG
ID:	163915Click image for larger version
Name:	3 scopes 3.JPG
ID:	163917Click image for larger version
Name:	Antenna array.jpg
ID:	163918 Note the final shot is not a Typhoon, but is clearer than some of the other shots. The Rim Hat hear appears to have 8 nodes, not six. Also the plans that come with the files seem to be in the correct order for scope/antenna position.
                        • hywel
                          • Aug 2022
                          • 65
                          Well, printing is done. Time spent is shown below...the times are all rounded up to the nearest hour, so this is a bit overstated, but close enough.
                          Click image for larger version  Name:	2022-08-19_13-45-29.png Views:	0 Size:	77.4 KB ID:	163978
                          I am doing some reprints of the rear rudder parts as the Elegoo resin is way too brittle for functional parts so I'm looking at another 9 hours of printing for those items.
                          Laying the sub out end to end gives me this...pretty much.
                          Click image for larger version  Name:	IMG_2947.jpeg Views:	0 Size:	68.2 KB ID:	163980
                          It's going to need a lot of reinforcement. I saw the USS Jimmy Carter being built by SubDude (I see what you did there) and am looking for carbon fibre tube to reinforce first before laying down the fiberglass matting. One section has warped slightly - nothing major but it needs correction. I'll need to make some doodads to hold the tubing to the hull most likely too. I'm really wondering how I'm going to keep this thing a consistent width so that the top is snug on the bottom. Thinking cap time - I'll have to wait until I get my starter kit from RCSubGuy to do a lot of this tho.
                          More soon...
                          • DrSchmidt
                            • Apr 2014
                            • 1336
                            Waht you need ist the elegoo ABS-lik resin.
                            • hywel
                              • Aug 2022
                              • 65
                              I haven't done a lot of experimentation with the Elegoo resins, but for sure, I need to find something different. Looks like this is the one you're referring to?
                              Most of my printing to date on the Mars has been ornamental stuff, but I'll try the ABS-like resin as a replacement to my usual.
                              • DrSchmidt
                                • Apr 2014
                                • 1336
                                #30
                                The standard resin is very, very brittle. I second that. For my Type XXIII project I print everything with the ABS-like resin, which has much more flexibility and is by far harder to break.
